Undo command problem or?
Chriss
Postby Chriss » Tue Feb 06, 2018 7:19 pm
Hi!
I'm new to FreeCAD and I find it very nice and helpful for hobbyists and pros maybe too, I'm not a pro.
OS: Windows 7
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
What is frustrating me day by day is the "UNDO" command.
If I put the mouse over the Undo icon, there is a tool tip with "Undo exactly one action".
Sometime when I click the Undo command it put my work back on a point where I was maybe at the beginning of my drawing
or on some place what actually is not my last action.
Here is an example:
1. Open a new drawing
2. Switch to PART workbanch
3. Create a cube (or whatever else)
4. Double click on the created cube
5. In the PROPERTY under BOX change the LENGTH and/or WIDTH (no matter what dimensions parameter you change)
6. The cube is re-dimensioned to the new value
7. Press the UNDO command
8. BINGO! the cube is deleted, your work is gone, looks like the last action was actually the "Create cube" command.
That makes no sense, an action for me is whatever I done in the past step by step.
In this case, for me would be more logical to change back the last changed dimension, than the dimension what was changed before and then the cube creation action.
Is this a bug or is this normal in FreeCad?
If this is normal, it is a big mistake.
The user should be concentrated how to make his/her work but not on "what was my last action" or more worse "was my last command an action or not?"
Thanks for any advice.
My best regards.
No matter what live you have, but how you use it...
Re: Undo command problem or?
Postby Kunda1 » Tue Feb 06, 2018 7:33 pm
please always post your Help > About FreeCAD > Copy to clipboard info when you post to the forums.
Chriss
Postby Chriss » Tue Feb 06, 2018 7:48 pm
Hi!
Sorry for the mistake.
Solved.
Postby Kunda1 » Tue Feb 06, 2018 9:07 pm
Can you test this on 0.17dev please?
Chriss
Postby Chriss » Tue Feb 06, 2018 9:24 pm
Ok, already tested, result are same as before version 0.16.
OS: Windows 7
Version: 0.17.13217 (Git)
Hash: 89275766de909a5c1f36e962806dc7b4a0b0f47b
OCC version: 7.1.0
Postby Kunda1 » Tue Feb 06, 2018 9:30 pm
AKA you can't reproduce the problem in 0.17 ?
Chriss
Postby Chriss » Tue Feb 06, 2018 9:38 pm
I can reproduce the problem in 0.17 also.
The same way as in 0.16.
cram
Postby cram » Wed Feb 07, 2018 1:17 am
I get the same behaviour as the OP in .17
Not with machine to post the build number
I had just assumed the behaviour was due to the parametric nature of freecad.
As I can undo creates objects but changes to dimensions don't undo.
sgrogan
Postby sgrogan » Wed Feb 07, 2018 1:38 am
Here is an example:
I can firm on
OS: Windows 7
Version: 0.17.13218 (Git)
Hash: 2990e1e7b03609b435a720ac7d263ba43bd72838
OCC version: 7.1.0
Same for the View tab as the Data tab. Re-do brings back the "Cube"
I think this should be a ticket. If it's a bug or not I can't say.
Postby Kunda1 » Wed Feb 07, 2018 4:08 pm
Thanks for bringing this to our attention and testing. Do you mind opening a ticket and linking it to this thread and linking this thread back to ticket?
sgrogan wrote:...
coincidentally an undo bug popped up on the tracker: issue #3339
