Undo command problem or?
meme2704
Re: Undo command problem or?
Post by meme2704 »
hi!
. BINGO! the cube is deleted
This is normally normal because the last function completed is "create 1 cube"
the episode "change length, width, height, position, angle are only variable data of the function" create cube "
Undoo only applies to a completed function
Chriss
Post by Chriss »
That's ok if you think it should be done that way, but the users are not programmers, they most of time spend
his/her time to construct something and not thinking if "this or that" is a variable or a completed task.
But the undo command is used in other apps too as the name say "un-do" or "change something back in a earlier stage".
The mentioned cube or whatever had a length of 30mm and now it has a length of 40mm.
I think a task was also created, now the new cube length is longer then in the stage before.
So, from this point of view, this has nothing to do with variables.
Of course the length and all other operations are related to variables, but that is on a programming level i think so.
I'm a programmer too and now how things goes under programming, but we have to think as the user, as a simple user who makes a
very complex creation as we make too when we write our lines of code and we must not at all mix up these two worlds.
Conclusion:
I think the undo command should undo any changes what was made in the past and should nothing have with functions or variables etc..
How deep, I mean how far can an undo command go back? that comes also in rolling but maybe 5-10 changes backward would be nice...
No matter what live you have, but how you use it...
Chriss
Post by Chriss »
Kunda1 wrote: Wed Feb 07, 2018 4:08 pm
Chriss wrote: Tue Feb 06, 2018 9:38 pm
Thanks for bringing this to our attention and testing. Do you mind opening a ticket and linking it to this thread and linking this thread back to ticket?
sgrogan wrote:...
coincidentally an undo bug popped up on the tracker: issue #3339
Yes, I mind to open a ticket and linking vise versa....
Kunda1 pls if you can do that linking pls do it.
meme2704
Post by meme2704 »
For this value you go to "Edit / Preferences / General / 2sd alinea you increase or decrease this value.
I personally, I am set to 20, but you can put a lot more
sgrogan
Post by sgrogan »
Kunda1 wrote: Wed Feb 07, 2018 4:08 pm coincidentally an undo bug popped up on the tracker: issue #3339
I'll test this as well.
This issue also came up independently in the 0.18 Whiteboard/Brainstorming thread https://forum.freecadweb.org/viewtopic. ... 10#p213889
"fight the good fight"
Post by Kunda1 »
Opened ticket issue #3341 for this issue.
Post by Kunda1 »
soft bump to keep this thread alive
