Removing dependency on QtWebKit
Re: Removing dependency on QtWebKit
Postby Kunda1 » Wed Jan 09, 2019 5:29 pm
mumme wrote:
Wed Jan 09, 2019 5:02 pm
Hi!
I found some time during christmas/new year holidays to code. :D
I ported FreeCAD to QWebEngine instead of QWebkit. If you're interested its located here.
https://github.com/mumme74/FreeCAD/tree/qwebengine
Thank you!
This is very generous. I'm still crossing fingers for development to restart on your python debugger. Thanks for all your work.
triplus
Postby triplus » Wed Jan 09, 2019 5:38 pm
mumme wrote:
Wed Jan 09, 2019 5:25 pm
It does however retain support for QWebKit, it is selectable through a CMAKE option.
Configure defaults to QWebKit if Qt is below Qt5.7
Great.
mumme
Postby mumme » Wed Jan 09, 2019 5:45 pm
Thank you!
Thanks! Im still hoping to get to that. Although that is probably spanning a bit to much for me as a hobby programmer alone.
My freetime schedule for satisfying that "coding itch" has been and will probably continue to be limited.
Anybody want to jump in and help/drive that project, you're more than welcome! ;)
Site Admin
Postby wmayer » Wed Jan 16, 2019 1:14 pm
I rebased your branch and open a merge request: issue #3774
Postby Kunda1 » Wed Jan 16, 2019 1:20 pm
@wmayer should we then close issue #2868?
Site Admin
Postby wmayer » Wed Jan 16, 2019 1:54 pm
I closed it.
Postby Kunda1 » Wed Jan 16, 2019 5:10 pm
:thumbsup:
mumme
Postby mumme » Thu Jan 17, 2019 5:45 am
Thank you!
It obviously needs more testing before merge.
For instance the webkit fallback isn't really tested by me.
Is it still the preferred method to open a merge bug report before all kinks are ironed out?
(Still trying to learn, how to do it right..)
Site Admin
Postby wmayer » Thu Jan 17, 2019 9:32 am
Thank you!
OK, it's good to know that it requires some testing.
Well, it makes sense to open a PR only then once you think you are done. It doesn't necessarily mean that everything works 100% correctly but that's why we do at least some testing to see if it causes problems.
Btw, since you are on github anyway it's best to make a PR there rather than opening a merge request ticket in mantis. I only did it in mantis because it'll be merged after v0.18 and I don't like to have too many pending requests in the queue.
