Ticket #3391 - #ERR getting Material properties dictionary values in spreadsheet cells
silopolis
Postby silopolis » Mon Feb 12, 2018 7:52 am
Keeping on working on my parametric cabinet master design, I'd like to get some parts material properties in spreadsheet cells but get an #ERR whatever syntax I try.
Could someone please tell me if this is possible at all and, if so, what's the appropriate way to do that ?
Thank you in advance for your help and have a nice week
Bests
Jérémie
Reason: Added ticket number to thread title
triplus
Re: #ERR getting Material properties dictionary values in spreadsheet cells
Postby triplus » Mon Feb 12, 2018 8:12 pm
Hi Jérémie.
Could you give an example (or maybe a file) on how you have assigned a material to a part. And explain further what values you would like to have in a spreadsheet. This effort AFAIK wasn't completed yet:
https://forum.freecadweb.org/viewtopic.php?f=10&t=16714
Therefore i am guessing we are talking about some Arch/FEM related features utilizing current material support FreeCAD has?
silopolis
Postby silopolis » Tue Feb 13, 2018 2:13 pm
I'm talking about Arch Materials. These can be assigned to Arch objects which can be created directly or from standard parts and/or sketches. I use mainly Arch Panels as wood panel pieces to design cabinets and furnitures.
If you look at the attached file, I've created a spreadsheet to hold the cutlist for the cabinet. I'm almost there (still have to find some way to handle arrays to be able to use them in my designs) but need to get some of the following dictionary values in cells:
>>> print App.ActiveDocument.Panel014.Material.Material
{'StandardCode': u'', 'Description': u'', 'Density': u'700 kg/m^3', 'DiffuseColor': u'(0.6666666666666666, 0.3333333333333333, 0.0)', 'Father': u'Aggregate', 'ProductURL': u'http://en.wikipedia.org/wiki/Wood', 'YoungsModulus': u'12000 MPa', 'Name': u'MDF-19mm', 'CardName': u'Standard Wood Material', 'PoissonRatio': u'0.05', 'AuthorAndLicense': u'(c) 2015 Bernd Hahnebach (CC-BY 3.0)'}
Thanks for the post pointer and for caring
LAM-STU-Modele_Caisson-v02c.fcstd
(66.5 KiB) Downloaded 12 times
triplus
Postby triplus » Tue Feb 13, 2018 2:38 pm
Panel014.Material.Material.<<get("Density")>>
triplus
Postby triplus » Tue Feb 13, 2018 3:41 pm
Note that i detected a small issue for this use case. And hopefully a fix or a working solution will be provided soon:
https://forum.freecadweb.org/viewtopic. ... 32#p214832
silopolis
Postby silopolis » Wed Feb 14, 2018 5:40 am
Good morning !
Thanks a lot for teaching me this syntax I didn't knew :)
Hopefully indeed ! This could be a great way to integrate FreeCAD in our process. Also discovered three things:
* All material properties fields are not created if you don't select an existing material to start from or open the ad-hoc window
* I can't multiply the obtained density because it comes as a string with unit
* User defined fields can be created which is just grrrreat... if only I could use them in spreadsheets ! ;-)
Thanks a lot for your help, will skim over the last pointed thread, could learn a couple of other things...
Have a nice day
Jérémie
triplus
Postby triplus » Wed Feb 14, 2018 1:50 pm
You're welcome. And indeed hopefully it will get sorted out in a way you will be able to achieve what you are after.
Re: Ticket #3391 - #ERR getting Material properties dictionary values in spreadsheet cells
Postby Kunda1 » Sat Nov 09, 2019 12:40 pm
