multithreading: CPU-utilization
Moderator: oliveroxtoby
thschrader
Postby thschrader » Mon Feb 26, 2018 10:56 pm
short question:
Why is FC consuming 18% cpu-loading when running an external program and FC is "not used"?
Here: simplefoam, running parallel on 4 cores.
oliveroxtoby
Re: multithreading: CPU-utilization
Postby oliveroxtoby » Tue Feb 27, 2018 5:48 am
Possibly writing the output to screen? If it's a small case then the output comes thick and fast and may consume quite a lot of processing to update the report view window. For a larger problem it should become negligible.
Please provide all the information requested in this post before reporting problems with CfdOF.
solosails
Postby solosails » Wed Mar 14, 2018 10:40 am
Not quite the same question, but is there a reason for not having a reconstructpar button having run a parallel case?
It's easy to open the folder and manually run reconstructpar, but would it not be a lot tidier to have the command within CFDOF?
oliveroxtoby
Postby oliveroxtoby » Wed Mar 14, 2018 11:54 am
We haven't found the need, since paraview can deal with the decomposed case directly. But we'll gladly accept this as a contribution ;-)
solosails
Postby solosails » Wed Mar 14, 2018 1:54 pm
I find that opening the deconstructed case in paraview ends up with weird blocks in the domain, However, if I reconstruct it using reconstructpar, all is normal?
