[Feature Request] Sketch - Identify Geometry Index (inside and outside Edit Mode)
Joel_graff
Re: Sketch - Identify Geometry Index (inside and outside Edit Mode)
Postby Joel_graff » Thu Mar 08, 2018 1:28 pm
paullee wrote:
Thu Mar 08, 2018 1:18 pm
Hope there will be more handy tool for these usages!
There will be, I'm sure ;)
Microelly and I had a good chat last Sunday about a complete workflow from layout design to modeling to visualization. The pieces are there, but it's going to take time to put them together well. Yorick''s BIM work eventually be a big part of this, too. But that's in the far distance, I think.
paullee
Postby paullee » Thu Mar 08, 2018 6:51 pm
Sure, I see there is discussion about Swept Path now - a familiar tool required in architectural modelling also!
Joel_graff
Postby Joel_graff » Thu Mar 08, 2018 6:58 pm
Really? How is it useful in Architecture?
paullee
Postby paullee » Fri Mar 09, 2018 1:13 pm
Yes, definitely!
Developing floor plan require from time to time traffic engineer to do swept path, like in a carpark, internal streets in a site!
paullee
Postby paullee » Wed Mar 14, 2018 7:03 pm
Feature Request submitted.
Hope someone could add this feature :)
[bug]https://www.freecadweb.org/tracker/view.php?id=3374[/bug]
realthunder
Postby realthunder » Fri Mar 23, 2018 10:18 am
Just stumbled upon this thread. This feature has been added to my branch when I implemented SketchExport, as you've already known. In my branch, the sketch elements are using the same name (but with different prefix for disambiguation) in and out of the edit mode. The ending integer (i.e. the 4 in ;SKT_g4) is the geometry ID, which is a new attribute (named ID) I added. You can match them (Sketch.Geometries) in a loop.
Screenshot from 2018-03-23 18-07-38.png (275.78 KiB) Viewed 396 times
Screenshot from 2018-03-23 18-08-00.png (239.27 KiB) Viewed 396 times
paullee
Postby paullee » Sat Mar 24, 2018 7:15 am
The Sketch Export Feature is one of those I hope it could be incorporated in the main branch immediately :)
I think it seems also solve another issue which I think is fundamental - consistent naming of edge component :D
Now, this may be the 3rd feature which is very handy for all those who are using sketch!!! :lol:
BTW, could it be something like Gui.Selection.getSelectionEx()[0].SubElement_INTERNAL_Index that it directly return the "i"ndex which save each user's code to write something to parse it?
Joel_graff should find this useful
Joel_graff wrote:"ping"
Busy reading FC's wiki, python etc. before I can understand Joel_graff's code!
Joel_graff
Re: [Feature Request] Sketch - Identify Geometry Index (inside and outside Edit Mode)
Postby Joel_graff » Sat Mar 24, 2018 2:12 pm
I did notice this - wonderful to have the id number as an attribute of the actual geometry!
paullee
Postby paullee » Sun Jul 14, 2019 8:48 pm
Hi, may i ask the status of this SketchExport + 'persistent sketch naming feature'? There are peoples drop into problems that I think these features should fix it :)
Thanks.
realthunder
Postby realthunder » Sun Jul 14, 2019 11:16 pm
Thanks.
I will try merge the Link functionality first, and followed by the topo naming thing including the sketch export. Hopefully it can get into 0.19 in time.
