Spreadsheet formula error on save/load
Postby chrisb » Fri Mar 02, 2018 7:02 pm
When I enter the following formula in a spreadsheet e.g. in cell A2
=A1 == 1 ? 1 : (A1 == 2 ? 2 : 3)
I get the result A2 equals A2 for values 1 and 2 and it is 3 for all other values.
Entering this formula removes immediately the brackets. The formula works still as described above.
However, if I save the file and reload it the formula looks like this:
=(A1 == 1 ? 1 : A1) == 2 ? 2 : 3
which yields different values, e.g. a value of 1 in A1 yields 3 in A2 instead of 1.
I attach a file, but keep in mind, that you get the changed formula on loading.
spreadsheetSaveReload.fcstd
(2.84 KiB) Downloaded 5 times
ulrich1a
Re: Spreadsheet formula error on save/load
Postby ulrich1a » Sat Mar 03, 2018 10:33 pm
I can confirm the issue. I made a bug-report: https://freecadweb.org/tracker/view.php?id=3363
The problem exist in the spreadsheet and in expressions, as they share the same library.
Ulrich
