VIIC 1:45 modell
Re: VIIC 1:45 modell
Hello Heiko,
thanks for the openfoam case. I had a first look, some hints:
In „constant/transportProperties“ the kinematic viscosity is set
to 1.0e-05, should be 1.0e-06 for water.
In „system/fvschemes“ a steady-state analysis is defined.
Then you should change the time entries in „system/controlDict“.
When running a steady-state calculation, the time is not a physical time
(as it is when doing a transient calculation), the parameter time works as an
incrementation counter for the iterations. Your entries should be
startTime=0
endTime=3000 (for ensuring convergence)
deltaT=1
writeInterval=20
As a first start I would not use a turbulence model. When calculating
the turbulence parameters „by hand“ or using this tool
https://www.cfd-online.com/Tools/turbulence.php
the turbulent kinetic energy/dissipation is nearly zero.
I will try to get the case running.
Thomas
startTime=0
deltaT=1
writeInterval=20
Thomas
Did a steady-state calculation without turbulence.
Solution converges after 180 iterations. The calculated
dragZ-force should be 100 times higher. Maybe a
problem with the mesh? When zooming in the mesh looks corrupt.
The computing-domain is a little bit small.
Time to get the problem into the FC cfd-wb...
what water speed did you use ?
you can check the quality of the mesh with checkMesh. Output says ok.
with transportProperties:
transportModel Newtonian;
nu [0 2 -1 0 0 0 0] 1e-06;
//mu 1e-3;
//nu 1e-6;
rho 1000;
These are the numbers i got so far.
//mu 1e-3;
//nu 1e-6;
rho 1000;
Hi Heiko,
there must be a point we both overlook.
At 0,5 m/s fluid speed, 0,5 m^2 projected frontal area and a drag-coefficient
of only 0,6 you get 37,5 N drag. To get 1 N drag like in your diagramm above, the drag coefficient
must fall down to 0,02. That is lower than the drag coefficient of a penguin (0,03), which
has the best coefficient of all animals. Mmmh..where is the bug?
Thomas
Thomas
aaah...
Heiko, the projected front area is not 0,5 m^2,
that is the value for the complete hull after using "integrate variables"-filter in paraview .
See my pic above, the slice through the flow channel. According to the blockmeshdict
the channel has an area of 0,3*0,35=0,11 m^2. The sub uses approx 1/6 of the area,
which gives 0,02 m^2 projected front area. Using this value, the total dragZ-force at 0,5 m^2/s
gives 1,5 N (cd=0,6). Not bad, your drag-diagramm is ok.
Thomas
Thomas
Hi Thomas,
these figures in paraview are more and more vodoo to me.
I scaled the VIIC up to 1:1 in FreeCAD.
1:45 speed 0,4m/s -> Drag 0,8N
1:1 speed 4m/s -> Drag 72100N
72100/scale^3 = 0,8 as expected.
Since uploading the files will take too long from home i can do that on Monday if you like.
Calculate Front Area in paraview (can't this be done in FC ???):
http://www.discretizer.org/node/20
That gives 0,014m^2 in 1:45 scale. Which seems correct given a max diameter of frame 54 of approx 14cm -> 0,0153m^2
Inspired from your last picture:
That is an amazing project.
... intense movie indeed.
Here are some findings from the foam simulation:
Forces at 0,5m/s water speed, rudder position 0° i.e. horizontal.
Rudder profile alone without hull: front +1.3e-6N (i.e. practically zero) ; aft +0.0026N
I think one cannot judge a rudder profile on it's own. It has to be done in context with the boat.
The lift force for the whole boat with the aft rudder 17.5° up results in +0.205N. i.e. The aft profile itself produces approx 25% of this force.
The faster the boat goes the more the aft is lifted and pushes the boat downwards by the symmetrical aft profile alone.
Cool i would have never thought of that. Thumbs up for FC plus openFoam !
The lift forces for a flattened profile:
Rudder profile with hull: front -0.005N; aft +0.042N; boat overall: -0.11N
Aft rudder semi flattend: front -0.005N; aft +0.025N; boat overall: -0.12N
Aft rudder flattend: front -0.005N; aft +0.006N; boat overall: -0.16N
Hi hds,
for getting the projected frontal area you can draw a sketch around the
(transparent) hull. Then upgrade the sketch to face and measure the area
with the „survey“-tool in arch-wb.
I did several calculations with the VIIC body, in the end I get a drag coefficient cd=0,31
at 0,5 m/s speed. With a „modern“ hull-form (length 1500 mm like your model)
cd is only 0,152.
Using this cd values for the original subs (upscaling factor 45) and 4 knots (2 m/s)
slow cruising speed the VIIC-type needs 38 kW power. The modern type,
which has more than double of the VIIC volume, needs only 45 kW (18% more).
regards Thomas
