Request for Pad improvement
efyx
Postby efyx » Thu Mar 15, 2018 2:24 pm
Please add thickness option. It means when I create open line for example L-shape I can Pad it with a thickness. Also auto fillets with predefinied radius should be possible. It is very usefull when you want create different profiles.
freecad-heini-1
Re: Request for Pad improvement
Postby freecad-heini-1 » Sun Mar 18, 2018 10:35 am
+1
Like a wall in the Arch workbench. Please thicknees minus, plus and symmetric.
And please add face / shell to pad and other PartDesign features, like extrude, revolve, loft and sweep in the Part workbench.
Postby chrisb » Sun Mar 18, 2018 11:51 pm
I don't understand: extrude, revolve, loft and sweep are available in Part and Part Design (with slightly different names).
freecad-heini-1
Postby freecad-heini-1 » Mon Mar 19, 2018 7:21 am
Loft and Sweep exists in PartDesign and Part and some other tools from other workbenches. So why not use faces as well in PD like most common CAD systems on the market?
polymer
Postby polymer » Fri Apr 20, 2018 8:24 pm
+1
That is the real “part design”!
freecad-heini-1
Postby freecad-heini-1 » Fri Jun 15, 2018 3:39 pm
Ping.
NormandC
Postby NormandC » Fri Jun 15, 2018 4:42 pm
ickby was open to allow creation of construction geometry in PD (I consider surfaces as construction geometry in the end goal of getting a solid). He did mention it on the forum.
Problem is, ickby already said he had no time to program for the foreseeable future. DeepSOIC doesn't either (or isn't interested). And nobody else seems interested in picking up PartDesign development. Apart from bug fixing, its development has stalled for almost a year.
So I'm afraid no amount of pinging or rehashing the same things will help change that.
freecad-heini-1
Postby freecad-heini-1 » Fri Jun 15, 2018 6:59 pm
Thank you so much for your answer Normand.
What about to use the clone tool Dolly to clone ickby Stefan?
Four copy please. One for his job, one for his family, one for his house and garden and one for Freecad. :lol:
NormandC
Postby NormandC » Fri Jun 15, 2018 7:21 pm
It was tried, with not really good results...
https://www.youtube.com/watch?v=SH2XDPI5664
freecad-heini-1
Postby freecad-heini-1 » Sat Jun 16, 2018 6:27 am
Ah, I see, seven would be fine, three for Freecad.
