Window does not cut hole in wall
Dgingrey
Postby Dgingrey » Sun Mar 25, 2018 7:45 pm
Version: 0.17.13452 (Git)
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 2.7.14
OCC version: 7.1.0
I am having a problem when adding a window to a wall using the Arch + button.
After adding the window to the wall it fails to cut a hole in the wall.
Window No Hole.PNG (80.41 KiB) Viewed 673 times
To get the hole cut I have to select the window and then select the wall in the combo view and then press the Arch - button.
Then the window appears with the hole cut correctly in the wall but the window disappears from the combo view.
Window Removed Hole Formed.PNG (89.97 KiB) Viewed 673 times
To get the window back into the combo view I have to select the window in the 3D view and then select the wall and press the Arch-
button again.
Window Removed 2nd time.PNG (72.88 KiB) Viewed 673 times
Now the window appears correctly in the wall in the 3D view and the wall and window are also in the combo view.
Is anyone else having this same problem.
yorik
Site Admin
Re: Window does not cut hole in wall
Postby yorik » Mon Mar 26, 2018 4:12 pm
Thanks for notifying.. It is now fixed in git commit a4714ce77
bitacovir
Postby bitacovir » Mon Mar 26, 2018 6:48 pm
mmmmm... I need a "windows with Arch+buttom" tutorial. I don't get it how to do it.
::bitacovir::
My Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Tue Mar 27, 2018 12:20 am
Basically if you insert a window directly on a wall, there is nothing to be done, it is done automatically for you. If you placed a window outside of any wall, and want to insert it later on, select the window(s), CTRL+select the wall (In Arch you always need to select the host last, so you can add several children to one parent, like Blender), then Arch Add (or Arch Remove, in case of windows, both do the same).
The effect of this is that the wall is added to the "Hosts" property of the window. You can do that manually too.
Recently I am more and more not binding windows to walls anymore, and instead I use a corresponding Part Cube as subtraction. I think it gives more control to have a "real" subtraction object. You can even make the cube adopt automatically the dimensions of the window...
bitacovir
Postby bitacovir » Tue Mar 27, 2018 10:57 am
Ok. Now I understand. Sometimes I draw a draft rectangle on a surface of a wall (selecting the face wall first) and then I transform the rectangle into a window. This cut a hole in the wall. Later I hide the window and then I have an opening in the wall. Not sure if this is ok instead of a more complex boolean operation.
::bitacovir::
My Blog
yorik
Site Admin
Postby yorik » Tue Mar 27, 2018 4:04 pm
Basically the window defines an invisible volume, which is built taking the biggest wire in the base shape of the window (sketch, draft rectangle, anything) and extrude in the normal direction of the window (given by its Normal property or calculated from the sketch plane otherwise), by the distance given by the HoleDepth property. When a wall is notified that it has a window (it is the window who "knows" that it is part of a wall, as it keeps the wall in its Hosts property), upon calculating its shape, it will subtract this invisible volume.
But this can also be done by hand, that is, have a window that is NOT inserted into a wall (its Hosts property doesn't contain the wall), it is just placed at the correct position "inside" the wall, and have another volume, that can be any shape, subtracted from the wall.
We grew used by major BIM applications to have windows "depend" on walls, but I'm wondering about the real need of this in real life... the IFC format, for example, makes a clear distinction between the wall opening (the "hole" needed to place the window) and the window itself.
I have the impression that it is much more useful, for example, to know to which space a window is related, than to which wall...
Dgingrey
Postby Dgingrey » Thu Mar 29, 2018 3:06 pm
This now works for windows created version 0.17 but if I try to add a window created using version 0.16 to a wall in version 0.17 it fails.
The window does not show up as being a part of the wall in the combo view, nor does it cut a hole in the wall in the 3D view.
Added Window not in wall.PNG (67.08 KiB) Viewed 492 times
yorik
Site Admin
Postby yorik » Thu Mar 29, 2018 7:57 pm
Ah indeed, that's because the 0.16 window doesn't have a "Hosts" property. you can fix that by selecting the window, and entering this in the python console:
FreeCADGui.Selection.getSelection()[0].addProperty("App::PropertyLinkList","Hosts")
After that it should work like a 0.17 window
Dgingrey
Postby Dgingrey » Thu Mar 29, 2018 9:05 pm
Are there any other properties the 0.17 window has that the 0.16 window doesn't that can be added in the same way?
paullee
Postby paullee » Fri Mar 30, 2018 12:45 am
Hi, i think we can currently have both!
And the former is good to keep IMHO.
  1. Currently window-wall host can be established by either which objects store the host properties.
  2. And, as most Arch Object accept Add+ object without further action - that's is a Convenient 'Workaround' for me as I said, so no need to change it :) - I can then 'link' arbitrary sketch to a Window Object, 'link' ArchWindow to ArchSpace ...
    https://forum.freecadweb.org/viewtopic. ... 19#p199555
    So as I 'link' different Windows to an Arch Space, I can summarize a list of windows in a particular Room(ArchSpace) in a Spreadsheet.
Hope it helps.
