Edit case issue
Moderator: oliveroxtoby
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 12:56 pm
If you mean as in the image, It opens at the correct file location
Could it be the fact that I am saving my cases on a different drive than the OS and the installation drive of Freecad and Openfoam?
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 1:00 pm
I do also get this message every time I open FreeCAD ...
Module: Part
Loading Part module... done
Loading Fem module... done
Loading GUI of Fem module... done
Init:      Initializing C:\Users\Woody\AppData\Roaming\FreeCAD\Mod\Cfd... failed
  File "<string>", line 120, in InitApplications
  File "<string>", line 87, in <module>
  File "<string>", line 34, in __init__
AttributeError: 'module' object has no attribute 'getModulePath'
During initialization the error 'module' object has no attribute 'getModulePath' occurred in C:\Users\Woody\AppData\Roaming\FreeCAD\Mod\Cfd\InitGui.py
Please look into the log file for further information
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 1:07 pm
Ahhh, I just removed the CFD add on (original add on) leaving only CFDOF and now it seems to work fine!
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 1:15 pm
Spoke too soon - it's opening in C/my documents again!
oliveroxtoby
Re: Edit case issue
Postby oliveroxtoby » Wed Mar 28, 2018 1:18 pm
Yup, that's what I meant. This is the command that CfdOF executes to open the folder, so I am stumped.
Do you mean that it actually fixes the edit folder issue? I did not expect that...
Please provide all the information requested in this post before reporting problems with CfdOF.
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 1:33 pm
Sorry, I thought it did, but tried a new case and have the same problem again - nevermind, it's not a big problem, thanks for looking into it!
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 1:36 pm
This is the command I see when I click edit
Successfully wrote OpenFOAM case to folder B:/CFD/freecad/Newfolder
Please edit the case input files externally at: B:/CFD/freecad/Newfolder\case333
Which is correct, but the window that opens is C:\Users\Woody\documents
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 1:47 pm
Ahhh, now, if I type in RUN
explorer B:/CFD/freecad/Newfolder\case333 (which is the address CFDOF is issuing) it opens up at my Documents ...
if I reverse the slashes as in
B:\CFD\freecad\Newfolder\case333
we get the correct folder...
oliveroxtoby
Re: Edit case issue
Postby oliveroxtoby » Wed Mar 28, 2018 1:55 pm
Great, thanks. Pushed an update that should fix that.
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 5:50 pm
Perfect, thank you! That appears to have solved it for me!
