dressup minor issues
Re: dressup minor issues
Postby chrisb » Wed Apr 04, 2018 8:52 pm
polymer wrote:
Wed Apr 04, 2018 7:55 pm
The Tool-Library definitely needs two extra options: ramp angle and min. diameter for helical ramping.
These options should be added as soon as someone starts coding. We have already tool parameters for future use. The data structure of the tool library is simple enough to add them as they are needed.
herbk
Postby herbk » Thu Apr 05, 2018 5:52 am
Both depends from the geometry of the tool.
I suggested some time ago at an other Thread: Ramp entry should be the standard at each path using a regular (square) shaped endmill, because also a endmilli with a cutting center gets a longer livetime if a ramp entry is used
Ramp angle depends on the tool, but helical ramping also depends on the workpeace (how much space for the helix?) to. So in my mind helical ramping should be placed in a dressup, not at the tool description.
But like chrisb said: we have a lott of (not used atm) parameters in the tooltable. Its confusing if asked for things with no effect, so keep the tooltable as it is, until a new function is added.
Gruß Herbert
polymer
Postby polymer » Thu Apr 05, 2018 10:38 am
Maybe in the future when Path can check if an operation is possible or not. (for example: cornerratius<tooldiameter, space for helical entry ...)
Than for some tool-parameter it would make more sense if they were placed in the tool-library.
roivai
Postby roivai » Thu Apr 05, 2018 4:55 pm
JoshM wrote:
Tue Apr 03, 2018 5:46 pm
I just ran an aluminum job and used Ramp dress-up on it. One thing that I noticed that surprised me was that the Ramp-Angle is specified relative to the Tool, not the Job, and so if I want to specify a Steep Ramp, I approach 0-Deg, and for a Shallow Ramp, I approach 90-Deg. This seems counter-intuitive to me.
The notation of the ramp angle has come from my head with no kind of thought how it should be defined.. So it definitely should be changed as the agreement seems to be that 90 deg should mean straight down. Maybe not before 0.17 release though?
Pekka
Postby chrisb » Thu Apr 05, 2018 5:43 pm
I am intrigued to say you are right, but on the other hand will 0.17 be the stable release for a very long time, making all models partly invalid for later versions, which use the 90-x angle. Now we are still in a prerelease where models are accepted to be invalidated.
mlampert
Postby mlampert » Thu Apr 05, 2018 6:41 pm
+1, it's now or never
roivai
Postby roivai » Thu Apr 05, 2018 7:56 pm
OK, I'll try to make a pull request during next weekend.
roivai
Postby roivai » Sat Apr 07, 2018 3:07 pm
Hmm, seems that I'm late for this party.. Here's the commit, but I suppose the release has been done already?
https://github.com/pekkaroi/FreeCAD/com ... 545ac486aa
Postby chrisb » Sun Apr 08, 2018 4:30 am
Yes it's released, but I guess there will be bugfix-releases before 0.18 is ready.
Oh, and thanks for the fix.
