Rebar schedules for box culverts
Joel_graff
Postby Joel_graff » Wed Apr 04, 2018 12:34 pm
Not that I mean to make more work for us around here, but...
I was just thinking the other day about how the rebar tool and the arch workbench are really well-suited for reinforced concrete design. More specifically, in my line of work, we often do custom rebar layouts for bridge decks and cast in place drainage structures (box culverts that pass underneath roads, manholes, and other junction-type structures).
Below is a link to a PDF of a standard box culvert design we use at the Illinois Department of Transportation (IDOT). It's a nice example of an industry-standard design document that FreeCAD is, in my opinion, capable of with a little extra effort... maybe. :)
http://www.idot.illinois.gov/Assets/upl ... tails.pdf
In any case, I don't know that it's worth pursuing at the moment - I'm trying to sort out how one could use these tools to do custom structure design in the transportation engineering sector. Still, I don't see much in the PDF plan sheets that FreeCAD couldn't reasonably produce if someone put their mind to generating the python code for it. The question is, how useful would it be to others outside my use case?
If there's any low-hanging fruit in this, it might be the ability to generate a rebar schedule (I don't see evidence this functionality exists yet). Essentially, it calls out each bar's name (usually designated by one or two characters like "h", "s1", "v", etc.), the number of bars that occur in the design, the bar size, the bar length, and a depiction of it's shape. There's also a tally of the structure's volume, the total weight of the rebar steel, the number of splicers required to join the rebar, and the square footage of permanent sheet piling (steel barriers used to retain earth while the hole is dug and the culvert is constructed). Some of that is determined by formulas or quantities that are a part of the design.
Anyway, see page 4 of the PDF link for details on the schedule of quantities.
Apart from that, I was wondering, has there been thought given to using FEM to analyze reinforced concrete structures?
Just for the sake of completeness, this ties into the Civil Engineering Workbench / Transportation Engineering discussions:
Civil Engineering Workbewnch wiki:
https://www.freecadweb.org/wiki/Civil_E ... rkbench/en
Transportation Engineering topic:
https://forum.freecadweb.org/viewtopic. ... &start=330
General Civil Engineering topic:
https://forum.freecadweb.org/viewtopic. ... &start=170
thschrader
Re: Rebar schedules for box culverts
Postby thschrader » Wed Apr 04, 2018 1:38 pm
No, because it is difficult.
In concrete engineering the structure (lets say a beam) is calculated at the limit state.
In the tension zone the concrete is cracked, you will need special programms to simulate
the cracks with FEM.
epsilon-c: compression-zone with elastic/plastic material behaviour (blue curve)
epsilon-s: tension zone, cracked, only the rebars can take tension loading (red).
The height of the cracked zone depends on the loading and the epsilon strain, wich must be
calculated iterative.
yorik
Site Admin
Postby yorik » Wed Apr 04, 2018 1:45 pm
cannot access the pdf link... can you check?
Joel_graff
Postby Joel_graff » Wed Apr 04, 2018 2:08 pm
That's what I suspected. It's been 20 years since I sat through a structural design class - your diagram brings back a lot of memories, lol. Anyway, I didn't expect there would be an FEM solution, but I thought it was worth asking.
Joel_graff
Postby Joel_graff » Wed Apr 04, 2018 2:12 pm
Downloads the pdf to my phone without an issue.
You can go to www.idot.illinois.gov, click on "Resources" at the top, then "Manuals and Guides" and scroll down until you see "Culvert End Section Details.pdf"
chakkree
Postby chakkree » Wed Apr 04, 2018 3:26 pm
Test create culvert object.
#-*- coding=utf8 -*-
   4 Apr 2018
import ArchComponent
import Part
from FreeCAD import Vector
data = [
{'S':1200 , 'R':1200 , 'Ts':125, 'Tt':190 , 'Tb':150 , 'L':1000}
class Culvert(ArchComponent.Component):
    def __init__(self, obj):
        ArchComponent.Component.__init__(self,obj)
        obj.addProperty("App::PropertyLength","Length","Culvert","Length of the box culvert").Length=1000
        obj.addProperty("App::PropertyLength","S","Culvert","").S=1200
        obj.addProperty("App::PropertyLength","R","Culvert","").R=1200
        obj.addProperty("App::PropertyLength","Ts","Culvert","").Ts=125
        obj.addProperty("App::PropertyLength","Tt","Culvert","").Tt=190
        obj.addProperty("App::PropertyLength","Tb","Culvert","").Tb=150
        obj.Proxy = self
    def execute(self, fp):
        L = fp.Length
        S = fp.S
        R = fp.R
        Ts = fp.Ts
        Tb = fp.Tb
        Tt = fp.Tt
        B = S+2*Ts
        H = R +Tb + Tt
        Box = Part.makeBox(fp.Length , B , H )
        points = [
          Vector(0, 2*Ts , Tb),
          Vector(0, S , Tb),
          Vector(0, S+Ts , Tb+Ts),
          Vector(0, S+Ts , R),
          Vector(0, S , R+Tb),
          Vector(0, Ts+Ts , R+Tb),
          Vector(0, Ts , R),
          Vector(0, Ts , Tb+Ts),
        L1 = Part.LineSegment(points[0] , points[1] )
        L2 = Part.LineSegment(points[1] , points[2] )
        L3 = Part.LineSegment(points[2] , points[3] )
        L4 = Part.LineSegment(points[3] , points[4] )
        L5 = Part.LineSegment(points[4] , points[5] )
        L6 = Part.LineSegment(points[5] , points[6] )
        L7 = Part.LineSegment(points[6] , points[7] )
        L8 = Part.LineSegment(points[7] , points[0] )
        line = Part.Shape([L1,L2,L3,L4,L5,L6,L7,L8])
        Wire = Part.Wire(line.Edges)
        face = Part.Face(Wire)
        void = face.extrude(Vector(L,0,0))
        concrete = Box.cut(void)
        fp.Shape = concrete
def makeCulvert( CulvertData , name='Culvert' ):
    S = CulvertData['S']
    Ts = CulvertData['Ts']
    R = CulvertData['R']
    Tb = CulvertData['Tb']
    Tt = CulvertData['Tt']
    L = CulvertData['L']
    B = S+2*Ts
    H = R +2*Tb
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython",name)
    Culvert(obj)
    obj.Length = L
    obj.S = S
    obj.R = R
    obj.Tt = Tt
    obj.Tb = Tb
    obj.Ts = Ts
    obj.ViewObject.Proxy=0
if __name__=='__main__':
    makeCulvert(data[0])
    FreeCAD.ActiveDocument.recompute()
    Msg('Done!\n\n')
Culvert_04Apr2018.py
(2.65 KiB) Downloaded 30 times
thschrader
Postby thschrader » Wed Apr 04, 2018 4:22 pm
my 2 cents. Should be possible...
culvert_rebar_test.FCStd
(83.97 KiB) Downloaded 34 times
Joel_graff
Postby Joel_graff » Wed Apr 04, 2018 7:58 pm
Definitely looks good. I've been kicking around the best approach - some of the designs are strctures that have angles and holes in them - which would suggest a CSG approach might be best. Also, is there a way to constrain the rebar positions with respect to the structure, such that if the structure resizes, the rebar adjusts with it?
thschrader
Postby thschrader » Thu Apr 05, 2018 12:42 pm
Yes, the rebars are based on sketches.
Tons of rebar stuff:
https://forum.freecadweb.org/viewtopic.php?f=8&t=22760
Joel_graff
Postby Joel_graff » Thu Apr 05, 2018 1:11 pm
Ok, thanks. That gives me enough to get started.
