Rebar tool failure
A forum dedicated to the Arch and BIM workbenches development.
Joel_graff
Rebar tool failure
Postby Joel_graff » Tue Apr 10, 2018 3:47 pm
Having trouble making the rebar tool work.
I've created a new document and added a wall section in the Arch workbench. I've added the rebar addon and restarted FreeCAD.
No additional rebar options / dropdown appears on the rebar tool button.
Running the rebar tool button gives me this error:
Please select a base face on a structural object
Running the Python command 'Arch_Rebar' failed:
  File "C:\Program Files\FreeCAD 0.17\Mod\Arch\ArchRebar.py", line 145, in Activated
    FreeCADGui.Control.showDialog(ArchComponent.SelectionTaskPanel())
Active task dialog found
Edit: system details:
OS: Windows 7
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Joel_graff
Re: Rebar tool failure
Postby Joel_graff » Tue Apr 10, 2018 4:17 pm
Update:
It appears that FreeCAD may be getting blocked on my network here at work...
yorik
Site Admin
Postby yorik » Tue Apr 10, 2018 5:40 pm
You need to install the Reinforcement addon.
The error is fixed in git commit 7101d9a89
Joel_graff
Postby Joel_graff » Tue Apr 10, 2018 6:35 pm
I did. It wasn't downloading because our network has issues with git. Sorted it out, though. I'll add an issue to the addon manager for erroneously telling me the addon successfully installed, though.
Joel_graff
Postby Joel_graff » Wed Apr 11, 2018 3:40 pm
Hijacking my own thread... but it's still related...
So I've tried building a basic box culvert and doing rebar layouts with the rebar tool.
culvert.FCStd
(26.27 KiB) Downloaded 10 times
I built the box culvert in Part Design using two sketches, the pocket sketch being externally linked to the pad sketch.
I saw it work correctly once... :)
thschrader
Postby thschrader » Wed Apr 11, 2018 5:11 pm
Now you can see it working correctly twice... :lol:
Transform the body into an arch "structure" object, the rebars love it.
Joel_graff
Postby Joel_graff » Wed Apr 11, 2018 5:44 pm
Beautiful!
I think I'm going to clone amrit's code and maybe stare at it for a while.
Adapting the rebar tool for this purpose requires some refinements... and at least one new rebar shape.
