xcb problem when starting new build of freecad
axk
Postby axk » Thu Apr 12, 2018 5:37 pm
Hi guys, I did a pull and managed to break my freecad with the following error:
FreeCAD 0.18, Libs: 0.18R13522 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
failed to create drawable
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
freecad: xcb_io.c:259: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed.
Aborted
I'm able to build from my linux repo's AUR, but it lacks support for my 3d mouse, so I'm trying to fix my local copy again.
The repo's build runs without issue (other than lack of support for my mouse), so it gives me hope that this is not a catastrophic error.
Freecad.log shows:
Log: X Error: BadValue (integer parameter out of range for operation) 2
  Major opcode: 53 (X_CreatePixmap)
  Resource id:  0x1e
Log: X Error: GLXBadPbuffer 179
  Extension:    155 (Uknown extension)
  Minor opcode: 28 (Unknown request)
  Resource id:  0x0
Log: This system does not support pbuffers
Any advice on how to resolve the xcb problem?
thanks in advance
gntech
Re: xcb problem when starting new build of freecad
Postby gntech » Thu Apr 12, 2018 6:04 pm
I have the same problem on Ubuntu. This problem is somehow related to DRI3. See https://forums.opensuse.org/showthread. ... ost2861858
A workaround is to either disable DRI3 for all applications by adding the following line to /etc/environment
LIBGL_DRI3_DISABLE=true
Or to disable DRI3 just for Freecad by launching freecad from the terminal with the following command.
LIBGL_DRI3_DISABLE=true freecad
(I posted the same reply earlier today in this thread https://forum.freecadweb.org/viewtopic. ... 5&start=20)
axk
Postby axk » Thu Apr 12, 2018 6:48 pm
Sincere thanks!! I did not see that earlier thread, sorry about duplication.
I will give the env setting a try.
axk
Postby axk » Thu Apr 12, 2018 7:07 pm
While I'm not sure how much of a performance hit I'd take from disabling DRI3, I tried backstepping mesa from 18.0.0 to 17.3.7 and that resolved my issue without resorting to DRI disables.
Thanks for the pointer to the SUSE thread.
Chris_G
Postby Chris_G » Thu Apr 12, 2018 8:03 pm
I had the same problem on Kubuntu 18.04
Thanks for the workaround.
The other workaround that work for me, is to use a KDE plasma Wayland session.
freecad-heini-1
Postby freecad-heini-1 » Wed May 23, 2018 7:59 am
I have the same problem with Xubuntu 18.04.
If I start Freecad with:
It start, but then my terminal is open and I can't open Freecad from Thunderbird or Thunar.
Any better solution for to solve this problem?
Postby chrisb » Wed May 23, 2018 8:35 am
You can try to start your browser with this environment variable set.
triplus
Postby triplus » Wed May 23, 2018 9:51 am
A workaround is to either disable DRI3 for all applications by adding the following line to /etc/environment:
That should apply it system wide. For local user you can set it in hidden .profile file inside your home folder.
gntech
Postby gntech » Fri May 25, 2018 5:47 pm
It should also be possible to modify the launcher as @triplus mentioned in another thread some time ago, see: https://forum.freecadweb.org/viewtopic. ... 20#p227288
nemesis
Postby nemesis » Mon Jul 09, 2018 2:49 pm
Hi Chris,
How did you enable Wayland with KDE?
I don't find clear informations on wayland / X11 ... I'm on Debian 9.4
