[0.17 release/0.18 daily/0.16 legacy] Ubuntu PPA users please read this
Re: [0.17 release/0.18 daily/0.16 legacy] Ubuntu PPA users please read this
Postby chrisb » Thu Apr 19, 2018 9:29 pm
martinsa wrote: Thu Apr 19, 2018 5:33 pm I cannot modify the page since I'm not an admin. Please can an admin modify it ?
Thanks for the find. I corrected it. If you want to contribute to the wiki you can get edit permissions: https://forum.freecadweb.org/viewtopic.php?f=21&t=6830
Dragonfly
Postby Dragonfly » Thu May 03, 2018 1:21 pm
I apologize if this is not the right place to post on the subject.
I got an error while FreeCAD-daily was updating today - a syntax error in /usr/lib/freecad-daily/MOD/Draft/Draft.py
there is a missing closing bracket on line 3701
FreeCAD daily 0.18 13660 (Git) 2018/05/02
system: Ubuntu Mate 16.04 (64 bit)
Taufeeq2
Postby Taufeeq2 » Fri Jul 20, 2018 2:46 pm
After installing the new freeCAD (0.17). The software carshes at start with this:
During initialization the error /usr/lib/freecad/lib/libSMESH.so: undefined symbol: _ZN23TCollection_AsciiString4SwapERS_ occurred in /home/nsamba/.FreeCAD/Mod/Cfd/InitGui.py
Please look into the log file for further information
During initialization the error /usr/lib/freecad/lib/libSMESH.so: undefined symbol: _ZN23TCollection_AsciiString4SwapERS_ occurred in /home/nsamba/.FreeCAD/Mod/assembly2/InitGui.py
Segmentation fault
NormandC
Postby NormandC » Fri Jul 20, 2018 7:20 pm
I think you need to make sure the upgrade process went properly.
Unfortunately this cannot be done in the GUI.
sudo apt-get update && sudo apt-get dist-upgrade
Site Admin
Postby wmayer » Sun Jul 22, 2018 9:24 am
What is the Cfd module? Could it be that it links against an older version of SMESH?
Taufeeq2
Postby Taufeeq2 » Sun Jul 22, 2018 4:34 pm
Is it possible to remove those faulty modules using freecadcmd?
Taufeeq2
Postby Taufeeq2 » Sun Jul 22, 2018 4:36 pm
The issue is now solved by deleting both the assembly and Cfd modules.
Thanks for your support!
R-INYURU
Postby R-INYURU » Wed Sep 19, 2018 6:43 am
Is it possible to install freecad-daily on Ubuntu 18.04,
I trying to do it but am getting this error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package freecad-daily
Trying to learn more about FreeCAD, any idea I will appreciate.
Postby chrisb » Wed Sep 19, 2018 8:19 am
R-INYURU wrote: Wed Sep 19, 2018 6:43 am Unable to locate package freecad-daily[/code]
You have to add the daily ppa: https://www.freecadweb.org/wiki/Install_on_Unix. BTW: a more descriptive title might help you and others, something like "HowTo install FreeCAD 0.18 on Ubuntu?".
R-INYURU
Postby R-INYURU » Wed Sep 19, 2018 5:58 pm
