PR#1445: [Stylesheets] updated and upgraded to SVG design
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
pablogil
Post by pablogil »
Finally had a little time to update all the png work into vector svg . :D
Full report:
  • minor fixes (updated to v2.09)
  • changed old .png files to vector .svg files
  • changed name of /images/ folder to /images_dark-light/ folder in order to let other designers to organize their new designs into separate folders. The suggested naming would be /images_xyz/ being "xyz" the theme main name.
The update is rebased and waiting at: https://github.com/FreeCAD/FreeCAD/pull/1445
Cheers
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
pablogil
Re: PR#1445: [Stylesheets] updated and upgraded to SVG design
Post by pablogil »
I have solved the issues (it was just a typo in the qss file names) and created a new PR so ignore or delete this one.
Go and check the correct one:
PR#1448 https://github.com/FreeCAD/FreeCAD/pull/1448
Thanks
