VTK pipeline, Broken warp filter
bernd
Re: VTK pipeline, Broken warp filter
Postby bernd » Tue Aug 07, 2018 10:54 pm
- open your file
- increase the value on the right side of the warp slider
- it works for me
- be sure Displacement --> Magnitude has values (has different colors)
OS: Debian GNU/Linux 9.5 (stretch)
Version: 0.18.14266 (Git)
Build type: Debug
Hash: 2e1a887c4c59fd1f3627eec9f3977c9b86fa523d
Python version: 2.7.13
OCC version: 7.0.0
Locale: German/Switzerland (de_CH)
bernd
Postby bernd » Tue Aug 07, 2018 11:13 pm
attached FEM 3D example file ...
bernd
Postby bernd » Tue Aug 07, 2018 11:23 pm
once if PR https://github.com/FreeCAD/FreeCAD/pull/1589 is merged it even works together with FEM clipping plane tool ... :D
HarryvL
Postby HarryvL » Wed Aug 08, 2018 12:18 am
Fantastic Bernd. Did you change anything? I mean do I need to pull and build the latest version?
bernd
Postby bernd » Wed Aug 08, 2018 7:02 am
No not for the warp. I just changed the scale values. They should get some smarter prev values. If you would like to use the FEM clipping plane with VTK post processing you need the latest fix which is in a PR ATM.
bernd
Postby bernd » Fri Aug 10, 2018 8:32 am
harry, do you get the warp filter work fo you?
HarryvL
Postby HarryvL » Fri Aug 10, 2018 9:01 am
Yes I did Bernd. Thanks. I should have reported back. What I don't understand is how I got it wrong in the first place because I always drag the scale slider to the right.
I am currently completely absorbed by the following: https://forum.freecadweb.org/viewtopic. ... 11#p249338
I thought I was smart ... buy a new and faster computer and do some serious development and computing, but instead since then the opposite happened - no more serious development and computing at all :shock:
bernd
Postby bernd » Fri Aug 10, 2018 9:46 am
The reason I'm asking in some rare cases it did not work for me either, but I could not repeat them. Which means I still have an eye on this. Most important is, in addition to drag the slider to the right, you need to adjust the max value on the right !!!
This is the main reason for not upgrading hardware or software. You spend hours before you really can start working again ...
UR_
Postby UR_ » Fri Aug 10, 2018 6:08 pm
On my rigg editbox's value seems to be clamped to 0...99,99 :(
So it's pretty useless, if max value is set to 5000 ;)
bernd
Postby bernd » Wed Aug 15, 2018 8:53 am
git commit 2772d1fa and some other small improvements
