Drawing 100 tooth HTD 3M timing pulley
ljoets
Postby ljoets » Wed May 16, 2018 1:57 pm
Hi all,
I have to draw a 100 tooth HTD 3M timing pulley and export it in SVG format (I just need a top view).
I found tooth profile characteristics here : https://www.solidrop.net/photo-7/cnc-ma ... ulleys.jpg
Is there a tip to draw it with FreeCAD ?
I am able to draw one teeth, but I don't know how to proceed after that.
What should be the correct way to do that ?
Thanks !
DeepSOIC
Re: Drawing 100 tooth HTD 3M timing pulley
Postby DeepSOIC » Wed May 16, 2018 2:24 pm
Draft Array (change it into polar using properties). Then, you can try exporting it as is. If you want to extrude it, you'll need to stitch it together. Maybe Fuse property of draft array will help, but if not, Part JoinConnect can.
ljoets
Postby ljoets » Wed May 16, 2018 2:48 pm
Thanks for your answer. But I know how to draw the first teeth in a sketch with "Part design". I don't know how to draw it with Draft toolbox. Is is possible to add constraints ?
ppemawm
Postby ppemawm » Wed May 16, 2018 2:52 pm
I would sketch the space between the teeth and cut it from the pulley. Then you can use PartDesign/PolarPattern. See the example below:
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
"It is a poor workman who blames his tools..." ;)
ljoets
Postby ljoets » Wed May 16, 2018 3:08 pm
Thanks,
that is a good idea, but I just need a top view in SVG format tu use it with a laser cutter or a CNC.
Perhaps FreeCAD is not the right tool to do this ?
DeepSOIC
Postby DeepSOIC » Wed May 16, 2018 3:20 pm
FreeCAD IS the right tool for the job!
You can extract the outline for an svg with quite a few methods, such as Draft Downgrade, or maybe Draft Shape2DView, or Part Common with a face.
It is not a problem, you can mix tools from different workbenches. Sure, there are limitations, but many workbenches can be combined to achieve the result.
My tutorial for Lattice2 add-on workbench might be helpful:
https://github.com/DeepSOIC/Lattice2/wi ... t-Tutorial
ppemawm
Postby ppemawm » Wed May 16, 2018 3:22 pm
Use the Drawing workbench to create the view then you can export as SVG file:
ljoets
Postby ljoets » Wed May 16, 2018 3:37 pm
Thanks to all !
I did the job !
oldmachine
Postby oldmachine » Wed May 16, 2018 4:24 pm
Just curious... Your opening comment & link suggests you want a HTD-M tooth. That is different than the one in the follow-up comments (radius'd bottom Versus rectangular...).
According to the dim's in the link, this is what the tooth looks like...
MAC OSX Sierra
3D Parts & Links (made using FreeCad and Solidworks): https://www.thingiverse.com/Still_Breathing/designs
Android App & Links: https://play.google.com/store/apps/deta ... .bestknots
ljoets
Postby ljoets » Wed May 16, 2018 7:01 pm
Is someone can tell me why 2 tooth are not cutted ?
Capture d'écran de 2018-05-16 20-56-48.png (23.61 KiB) Viewed 2317 times
Capture d'écran de 2018-05-16 20-56-38.png (2.51 KiB) Viewed 2317 times
Poulie HTD-3M 100T.fcstd
(229.94 KiB) Downloaded 107 times
Thanks ;-)
