Plotting of Concrete Reinforcement Ratio
HarryvL
Re: Plotting of Concrete Reinforcement Ratio
Postby HarryvL » Mon Jul 09, 2018 10:10 am
Interestingly, if I make Solid1 steel and Solid2 concrete I get:
object Name: Concrete
object.References: [(<Part::PartFeature>, ('Solid2',))]
CONCRETE
  ReferenceShape ... Type: Solid, Object name: BooleanFragments, Object label: BooleanFragments, Element name: Solid2
The limit if a node is in or out: 0.000000100000 in scientific: 1.0000e-07
<type 'list'>
concrete nodes: [5L, 6L, 7L, 8L, 9L, 10L, 11L, 12L, 18L, 21L, 23L, 24L, 25L, 26L, 27L, 28L, 29L, 30L, 31L, 32L, 58L, 59L, 60L, 61L, 62L, 63L, 64L, 65L, 66L, 67L, 68L, 69L, 70L, 71L, 72L, 73L, 74L, 75L, 76L, 77L, 78L, 79L, 80L, 81L, 82L, 83L, 84L, 85L, 86L, 87L, 101L, 102L, 103L, 104L, 105L, 106L, 107L, 108L, 109L, 110L, 111L, 112L, 113L]
So it seems femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref) returns 100 for Solid1 and 113 for Solid2, whereas the total mesh only has 113 nodes.
bernd
Postby bernd » Mon Jul 09, 2018 1:12 pm
ok, thanks for the aditional informations. I will have a look.
Bernd
HarryvL
Postby HarryvL » Tue Jul 10, 2018 3:21 am
CONCRETE
<type 'list'>
Urrrrrrr. Actually it is 63 nodes if you count the list. It just happens so that node number 113 is part of the list. So maybe it is right after all !! ... Yup, the list for the example with Solid1=concrete and Solid2=steel also has 63 nodes and happens to end with node 100.
Sorry for dragging you into my confusion. I think the only problem was indeed the group meshing as you indicated. So, thanks for your help.
PS: what is this group meshing for? Should it perhaps be switched off by default?
bernd
Postby bernd » Tue Jul 10, 2018 9:17 am
Does it mean everything runs smooth without group meshing? :?:
If group meshing is activated, the following happens ...
- on meshing with GMSH for every FEM document object with reference shapes a group of nodes is created
- on writing ccx input file, if there is a group with exact the same name as an object with reference shapes the group nodes are taken and used to write the input file, means no node search in the mesh. This speeds up inp file writing enormous, but seams not to work propperly in any case.
AFAIK, it should be deactivated by default. I will hava a look.
bernd
Postby bernd » Tue Jul 10, 2018 11:04 am
It is active by default https://github.com/FreeCAD/FreeCAD/blob ... ls.py#L268. I will deactivate it by default in my next PR.
HarryvL
Postby HarryvL » Tue Jul 10, 2018 1:23 pm
I think it does Bernd.
I will add a warning/error for the case mesh grouping is switched on, because that would crash my routine (node number > number of stress results)
Thanks again
HarryvL
Postby HarryvL » Tue Jul 10, 2018 1:24 pm
Thanks. That makes more sense IMHO
bernd
Postby bernd » Tue Jul 10, 2018 9:55 pm
bernd
Postby bernd » Thu Jul 12, 2018 4:33 pm
git commit 3416a26d7
bernd
Postby bernd » Tue Mar 26, 2019 10:24 pm
HarryvL wrote:
Sat May 19, 2018 12:13 pm
I coded the 13 closed form solutions for reinforcement ratio defined here: http://heronjournal.nl/53-4/3.pdf with Python and managed to reproduce the 11 test cases for single stress results (I changed the name for the reinforcement ratio from "Omega" to "Rho" in line with the paper):
Case 1
Sigma:        2.000   -2.000    5.000    6.000   -4.000    2.000
Governing Eq.14    Rho: 0.02400 0.00400 0.01400
Case 2
Sigma:       -3.000   -7.000    0.000    6.000   -4.000    2.000
Governing Eq.10+   Rho: 0.00886 0.00000 0.00571
Case 3
Sigma:       -1.000   -7.000   10.000    0.000    0.000    5.000
Governing Eq.5     Rho: 0.00000 0.00000 0.02714
Case 4
Sigma:        3.000    0.000   10.000    0.000    5.000    0.000
Governing Eq.13    Rho: 0.01600 0.00000 0.03000
Case 5
Sigma:       10.000    7.000   -3.000    3.000    1.000   -2.000
Governing Eq.11-   Rho: 0.02533 0.02133 0.00000
Case 6
Sigma:        4.000   -7.000    3.000    7.000    0.000   -5.000
Governing Eq.14    Rho: 0.02200 0.01000 0.01600
Case 7
Sigma:        8.000  -14.000    6.000   14.000    0.000  -10.000
Governing Eq.14    Rho: 0.04400 0.02000 0.03200
Case 8
Sigma:        1.000    0.000    3.000   10.000   -8.000    7.000
Governing Eq.17    Rho: 0.02486 0.01750 0.01720
Case 9
Sigma:        0.000    0.000    0.000   10.000    8.000    7.000
Governing Eq.13    Rho: 0.03600 0.03400 0.03000
Case 10
Sigma:       15.000    0.000    0.000    0.000    0.000    0.000
Governing Eq.13    Rho: 0.03000 0.00000 0.00000
Case 11
Sigma:        0.000    0.000    0.000    5.000    0.000    0.000
Governing Eq.13    Rho: 0.01000 0.01000 0.00000
Next step the integration in FreeCAD or Paraview
we should make an unit test for them to make your code save
