[BUG?] Cropped icons
Since a time, and I think only in Qt5 builds, I'm experiencing the following: my laptop has a retina display (macbook pro) and when placing the FreeCAD window in that screen all icons show correctly. But if I connect an external monitor with regular pixel density and place the FreeCAD window in that screen then the "file" and "view" tools scale and crop like the following screenshot: If I place back the FreeCAD window to the retina display it refreshes and show the icons correctly, but if place it back to the external monitor then they are back scaled and cropped.
The curious thing is that I have checked that if I use @triplus "IconThemes" addon it does correctly scale the icons: Any idea? is it a bug or maybe a problem with icons sizes? by now I can't build a custom FreeCAD so I can't try it out by myself...
Thanks
Thanks
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Re: [BUG?] Cropped icons
You reported this issue quite a while ago, but I guess no one has had time to fix it. https://freecadweb.org/tracker/view.php?id=3130
Hi Pablo.
I can take a look at weekend. To see if anything obvious is at play. If i understand the issue correctly this only happens for the commands located on the View toolbar?
The problem is the same one but not the approach... I mean, I have discovered that with IconThemes the problem is solved but I don't know why so I thought it was a nice option to ask triplus about it. Maybe for his is trivial and he can solve it easily...peterl94 wrote: ↑Sun May 20, 2018 6:43 pm You reported this issue quite a while ago, but I guess no one has had time to fix it. https://freecadweb.org/tracker/view.php?id=3130
It only happens in file and view toolbars
Thanks!
Problem solved.
Thanks for the feedback. Will take a look to see if any obvious clues emerge (at weekend).It only happens in file and view toolbars
Thanks!
Great!
So was it easy to solve?
If you anywhere have the pull request I will test it, thanks
Nah not solved yet! I was saying there i guess is a solution to the problem available.
P.S. As for looking into the issue i won't have time to do that before weekend.
Hahaha, sorry, sorry, I misunderstood you.
Yes, you are right, I solved it duplicating these icons into a new Theme and using it as default
Don't worry, take your time, it was just an idea that you would know about how to solve the issue...
Thanks
