material editor
A forum to discuss the implementation of a good Materials system in FreeCAD
bernd
Re: material editor
Postby bernd » Wed May 30, 2018 7:53 pm
test on 0.17 on win
import MaterialEditor
MaterialEditor.openEditor()
the material editor opens. press open nothing happens, press ok nothing happens ...
OS: Windows 7
Version: 0.17.13510 +12 (Git)
Branch:
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Locale: German/Switzerland (de_CH)
bernd
Re: material editor
Postby bernd » Wed May 30, 2018 7:54 pm
test on 0.18 on win
OS: Windows 7
Version: 0.18.13826 (Git)
Hash: 3b02ff2a9481f0883063c7e24c312978ef0ce642
OCC version: 7.2.0
[/quote]
bernd
Re: material editor
Postby bernd » Wed May 30, 2018 8:23 pm
https://github.com/berndhahnebach/FreeC ... diff=split but exec_ blocks FreeCAD while the mat editor runs.
bend
bernd
Re: material editor
Postby bernd » Fri Jun 01, 2018 6:30 am
yorik
Site Admin
Re: material editor
Postby yorik » Fri Jun 01, 2018 2:30 pm
Ah indeed there were a lot of fixes needed :D thanks!
yorik
Site Admin
Re: material editor
Postby yorik » Fri Jun 01, 2018 2:34 pm
damian wrote:
Wed May 30, 2018 6:26 pm
I've got in my agenda, of June, a very similar question. I would like to learn about this ...
I recenly did that here if you want an example: https://github.com/yorikvanhavre/BIM_Wo ... lements.py
Basically you need to use a QTreeView instead of a QTreeWidget, and make a model yourself, which is the "entity" whick keeps/organizes the data of a tree widget, and give it a custom QStyledItemDelegate which handles the actions when you want to edit an item of the tree
damian
Re: material editor
Postby damian » Sat Jun 02, 2018 6:46 am
from this ugly 'text box'
to a nice widget
okey
Jee-Bee
Re: material editor
Postby Jee-Bee » Sat Jun 02, 2018 6:57 am
A note based on above figure. Poisson ratio is a mechanical property. Could that move??
damian
Re: material editor
Postby damian » Sat Jun 02, 2018 7:05 am
is there any inconvenient in to use QTreeWidget with setItemWidget()?
Edit:
https://stackoverflow.com/questions/278 ... treewidget
But the Model/View approach is more general and flexible IMO. You can create your own subclasses of model and view which enables you to do whatever you like.
okey
damian
Re: material editor
Postby damian » Sat Jun 02, 2018 10:53 am
Off topic:
I'm seeing the mechanism
Gui::InputField
but I see it exclusively with ui files
If I do it from python, only pySide no ui file,
ui = FreeCADGui.UiLoader()
widget = ui.createWidget("Gui::InputField")
widget.
Could have I got the unit parser system working in my widget (exclusively with pySide, no ui)?
Is mandatory the ui file for this?
Are there more options than Gui::InputField and Gui::QuantitySpinBox?
