Getting the sketcher geometric elements that the solver indicates as dependent
abdullah
Postby abdullah » Fri Jun 08, 2018 7:34 pm
I have written a new Python function of the sketch object (aka ActiveSketch), which provides the elements that the solver indicates they have dependent parameters (so they are not constraint, are movable,...). I looks like this:
>>> ActiveSketch.getGeometryWithDependentParameters()
[(0L, 2L), (0L, 0L)]
So it returns a list of tuples, each tuple being (GeoId,PosId).
Any input before I PR it?
Re: Getting the sketcher geometric elements that the solver indicates as dependent
Postby Kunda1 » Sat Jun 09, 2018 12:31 am
I think @Joel_graff might dig this
Joel_graff wrote:poke
Joel_graff
Postby Joel_graff » Sat Jun 09, 2018 11:58 am
Hmmm.. I admit I'm not sure, exactly, what that does...
abdullah
Postby abdullah » Sat Jun 09, 2018 2:08 pm
You ask:
You get replied with a list of tuples:
each element of the list represents an edge or a vertex. The first element of the tuple is the GeoID, the second element of the tuple is the PosID. For example, with the output above the Sketcher is telling you: "The solver detects that the endpoint of the element with GeoID=0 is not fully constraint, so it is "movable", or if you want you need to constraint it, directly or indirectly, if you want to arrive to a fully constraint sketch. The same happens with the Edge of the geometry with GeoID=0. It is basically telling you were your DoFs are.
Joel_graff
Postby Joel_graff » Sun Jun 10, 2018 1:05 pm
You ask:
Ahhh. gotcha. Very clear! That looks really useful.
Postby Kunda1 » Mon Jun 11, 2018 12:07 am
You ask:
Is there a documentation page where we can quickly post that tidbit to ?
abdullah
Postby abdullah » Mon Jun 11, 2018 4:43 pm
You ask:
None to my knowledge.
Documentation from code will be generated... whenever it is generally generated, but probably it would be great to have all this bits somewhere...
