Another approach to assembly solver (A2plus)
fc_tofu
Re: Another approach to assembly solver (A2plus)
Postby fc_tofu » Sat Feb 01, 2020 8:50 pm
kbwbe wrote: Sat Feb 01, 2020 8:32 pm
fc_tofu wrote: Sat Feb 01, 2020 4:22 pm I made some menu and tooltip polish at A2plus 0.4.36 for personal use...
Hi @fc_tofu,
the structured menu really looks better. Please upload the InitGui.py file.
Thank you.
Sent already, receive with PM plz.
triplus
Postby triplus » Sat Feb 01, 2020 9:11 pm
Good job @fc_tofu one the menu work.
kbwbe
Postby kbwbe » Sat Feb 01, 2020 9:16 pm
Hi people,
i like to demonstrate how to use some new features of A2plus V0.42.
Now it is possible, to design things with A2p using the mastersketch approach. Everything is still within separate files.
phpBB [video]
The workflow was roughly this:
1) create a file "master.FCStd" and do sketch within this and save it.
2) create a file "Part-1". Import the sketch of the masterdoc by using this button:
3) switch to PartDesign WB, create a body and use the imported sketch as basefeature
4) Design your part, having the geometry of the imported sketch as external geometrie. Save your part.
5) Do the same things for the second part
6) create an assembly file
7) import the sketch from the masterdoc with this command again
8) Import the 2 parts and constraint them against the imported sketch
9) Assure that "master.FCStd" and "assembly.FCStd are opened.
10) start the script.
Very interesting is, that everything is in a separate file. The mastersketch can be used both for design of the parts and for the simulation.
P.S. The script animates the mastersketch. It's Shape is transferred by the script to the assembly. Solving the assembly moves the parts.
Have Fun.
Files are attached.
a2p-master-sketch-approach.zip
(76.54 KiB) Downloaded 37 times
KBWBE
latest release: v0.4.54b, installable via FreeCAD's addon manager
uwestoehr
Postby uwestoehr » Sat Feb 01, 2020 9:29 pm
kbwbe wrote: Sat Feb 01, 2020 9:16 pm Have Fun.
Cool! :+1:
Turro75
Postby Turro75 » Sun Feb 02, 2020 12:10 pm
kbwbe wrote: Sat Feb 01, 2020 9:16 pm Hi people,
Great! this is a powerful enhancement!
m.cavallerin
Postby m.cavallerin » Mon Feb 03, 2020 8:01 pm
kbwbe wrote: Sat Feb 01, 2020 9:16 pm Now it is possible, to design things with A2p using the mastersketch approach. Everything is still within separate files.
Hi kbwbe,
that's for sure an useful tool, but it seems a clone of the "Link" function, am I wrong?
If the same functionality could be covered by Link, It would be useful to think this tool revisited with link functionalities.
That's only a suggestion, just for standardization; in any case you made a great work so far!
Regards.
Michele
triplus
Postby triplus » Mon Feb 03, 2020 8:17 pm
m.cavallerin wrote: Mon Feb 03, 2020 8:01 pm that's for sure an useful tool, but it seems a clone of the "Link" function, am I wrong?
There were some discussions in the past, but AFAIK currently App::Link doesn't support linking to Sketcher geometry from an external docment.
kbwbe
Postby kbwbe » Mon Feb 03, 2020 8:25 pm
Hi Michele,
before creating this tool, i tried to use links for that. But i didn't success. (Perhaps my lack of experience with links). I am wondering if standard FC0.19 (not Asm3) is capable to do the same example by using links. E.g. i was not able to use a linked sketch as basefeature for PartDesign. Any hint is appreciated.
Klaus
P.S. this post overlaped with @triplus' one.
KBWBE
triplus
Postby triplus » Mon Feb 03, 2020 8:32 pm
The way i see it App::Link was merged, that much is true, but only now use cases and feedback will come. Therefore hopefully development wont stop just yet and better to be vocal about your needs.
P.S. Ask first, develop latter. ;)
m.cavallerin
Postby m.cavallerin » Mon Feb 03, 2020 8:51 pm
triplus wrote: Mon Feb 03, 2020 8:17 pm
I knew there was a reason, but I didn't know the technical difficulties to get the result, now it's all clearer to me.
Thank you both.
Regards Michele.
Reason: fixed broken bbcode
