Another approach to assembly solver (A2plus)
kbwbe
Re: Another approach to assembly solver (A2plus)
Postby kbwbe » Wed Aug 01, 2018 4:25 pm
Turro75 wrote:
Wed Aug 01, 2018 5:58 am
@Kbwbe
@project4
Is there a way to check every x thousand steps if the solver is doing well and movement rotation are acctually reducing the gap to the target?
Hi @Turro + @project4,
it is inside branch "devel" now. There are some new parameters at head of "solversystem.py".
SOLVER_STEPS_CONVERGENCY_CHECK = 1000
SOLVER_MIN_CONVERGENCY_RATE = 0.9999
SOLVER_CONVERGENY_ERROR_INIT_VALUE = 1.0e+20
I tested these values and this combination worked for my assemblies. The values detect surely if a constraint is not solvable. It was not possible to set SOLVER_MIN_CONVERGENCY_RATE = 0.99. In this case, some test cases did not work anymore. Perhaps you can play with the values for your assemblies.
Most work is implemented in Rigid.calculateWorkList(). It looks now as:
    def calculateWorkList(self, doc, workList):
        self.printList("WorkList", workList)
        for rig in workList:
            rig.enableDependencies(workList)
        self.lastPositionError = SOLVER_CONVERGENY_ERROR_INIT_VALUE
        self.lastAxisError = SOLVER_CONVERGENY_ERROR_INIT_VALUE
        self.convergencyCounter = 0
        calcCount = 0
        goodAccuracy = False
        while not goodAccuracy:
            maxPosError = 0.0
            maxAxisError = 0.0
            calcCount += 1
            self.stepCount += 1
            self.convergencyCounter += 1
            # First calculate all the movement vectors
            for w in workList:
                w.calcMoveData(doc, self)
                if w.maxPosError > maxPosError:
                    maxPosError = w.maxPosError
                if w.maxAxisError > maxAxisError:
                    maxAxisError = w.maxAxisError
            # Perform the move
            for w in workList:
                w.move(doc)
                # Enable those 2 lines to see the computation progress on screen
                #w.applySolution(doc, self)
                #FreeCADGui.updateGui()
            # The accuracy is good, apply the solution to FreeCAD's objects
            if (maxPosError <= self.mySOLVER_POS_ACCURACY and
                maxAxisError <= self.mySOLVER_SPIN_ACCURACY):
                # The accuracy is good, we're done here
                goodAccuracy = True
                # Mark the rigids as tempfixed and add its constrained rigids to pending list to be processed next
                FreeCAD.Console.PrintMessage( "{} counts \n".format(calcCount) )
                for r in workList:
                    r.applySolution(doc, self)
                    r.tempfixed = True
            if self.convergencyCounter > SOLVER_STEPS_CONVERGENCY_CHECK:
                if (
                    maxPosError > SOLVER_MIN_CONVERGENCY_RATE * self.lastPositionError or
                    maxAxisError > SOLVER_MIN_CONVERGENCY_RATE * self.lastAxisError
                    FreeCAD.Console.PrintMessage( "System not solvable, convergency is to bad !\n" )
                    return False
                self.lastPositionError = maxPosError
                self.lastAxisError = maxAxisError
            if self.stepCount > SOLVER_MAXSTEPS:
                FreeCAD.Console.PrintMessage( "Reached max calculations count ({})\n".format(SOLVER_MAXSTEPS) )
                return False
        return True
P.S.: @Turro75: I opened branch "turro" at github for your PR's
KBWBE
latest release: v0.4.49, installable via FreeCAD's addon manager
manuelkrause
Postby manuelkrause » Wed Aug 01, 2018 5:44 pm
Now that the solversystem outputs so much info about included parts... Wouldn't it be great upon failing _changed_ imported parts, that the solver just reminds "Please check part xyz for changed constraints!" with xyz being the part where the solver exited? I mean, instaed of all the error messages in the Report view.
dep2.refPoint = circleEdge2.Curve.Center
'Part.Line' object has no attribute 'Center'
Manuel
manuelkrause
Postby manuelkrause » Wed Aug 01, 2018 6:44 pm
With the devel code from yesterday evening I also get completely inconsistent part placements after constraining:
Please have a look:
Manuel
project4
Postby project4 » Wed Aug 01, 2018 6:48 pm
Manuel
@kbwbe
I had a similar thought in that direction as well few weeks ago.
We should probably replace all the FreeCAD.Console.Print calls to a2p.print (or something like that, I don't remember the existing function name).
We could add the severity parameter to the print function (CRITICAL, ERROR, WARNING, DEBUG) and the function will print only messages with higher severity than global configuration. Similar to any Linux debug functionality...
That way we won't need to remark all the debug printouts all the time, only change the global.
kbwbe
Postby kbwbe » Wed Aug 01, 2018 7:37 pm
Hi Manuel, in devel code from yesterday evening nothing concerning part placements was changed. Did you try "alltogether" mode ?
KBWBE
kbwbe
Postby kbwbe » Wed Aug 01, 2018 8:10 pm
Manuel
@kbwbe
Hi @project4 + @manuelkrause
these are two different types of messages.
1) the messages generated by ourself, easy to reduce...
2) freecad error messages, which has Manuel now, because of reimporting modified parts without deleting the related constraints before that . (as being recommended ATM)
I will have a look at both types.
At 1): modification according to your (@project4) suggestions
At 2): what Manuel needs is a clear message which reimported part breaks it's constraints. If there are FreeCAD errors, it is possible. But if FreeCAD gives no error, because of linking so same type of geometric element (but a false one), it can not be catched and Manuel will still have his problem.
KBWBE
manuelkrause
Postby manuelkrause » Wed Aug 01, 2018 8:14 pm
Mmmh. The main assembly was done with earlier versions of A2plus. I've only removed the potential error-causing constraint (according to 'Report view' last failing one, what never was the culprit) and then went on constraining).
And yes, it happens with both "'alltogether" and "partial" -- maybe there's a re-action from the "toggle" mode.
Manuel
manuelkrause
Postby manuelkrause » Wed Aug 01, 2018 8:28 pm
Manuel
@kbwbe
Please, keep calm, I've only made some very humble proposals.
But please write, where the new development goes! "/devel/" ?
Turro75
Postby Turro75 » Thu Aug 02, 2018 11:24 am
@Kbwbe
@project4
        calcCount = 0
            maxPosError = 0.0
            maxAxisError = 0.0
            calcCount += 1
            self.stepCount += 1
            for w in workList:
            # Perform the move
            for w in workList:
                w.move(doc)
                goodAccuracy = True
                for r in workList:
                    r.tempfixed = True
                if (
                    return False
                return False
        return True
Hi Kbwbe,
Why do you apply the min convergency rate? It wasn't enough comparing max error with the last one?
kbwbe
Postby kbwbe » Thu Aug 02, 2018 11:43 am
Hi @Turro75,
it' so simple that i did not see it. I will try out.
KBWBE
