How to create a job for multiple holes
micksulley
Postby micksulley » Mon Jul 02, 2018 9:15 pm
OS: Linux Mint 18.3 Sylvia
Version: 0.18.13959 (Git) AppImage
Build type: None
Hash: 2f18182b6dff87f8857787c854e39ca4d441f993
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
I have created a plate with a matrix of counterbored holes (attached). What I would like to do is create a job which uses a 5mm tool to pocket the holes (7mm dia) and the 19mm counterbore.
I have manages to do that but I think there must be a better way, 2 issues -
1) I have 60 holes and I only know how to do it by adding each hole into the Base Geometry for each hole and each counterbore. Is there a way to select them all?
2) From the simulation it is going to do a first level cut on each hole in turn, then go back and do a second level cut, etc. Is there a way to perform all cuts on the first hole, then move to the second, etc
Thanks
Mick
HoleTest2.fcstd
(92.15 KiB) Downloaded 11 times
sliptonic
Re: How to create a job for multiple holes
Postby sliptonic » Tue Jul 03, 2018 12:51 am
Rather than select the individual faces of the holes, select the top face for the counterbore and the bottom face for the through-hole.
Updated file attached.
HoleTest2.fcstd
(109.44 KiB) Downloaded 13 times
Postby chrisb » Tue Jul 03, 2018 6:25 am
If you want to drill the holes you can use the PathArray, at least in one dimension.
In the attached example I linked offset and number of copies to the LinearPattern.
It would be great if it was possible
- either be able to define the copies in three dimensions
- or be able to create PathArray of PathArray
HoleTest_CB.fcstd
(72.51 KiB) Downloaded 10 times
micksulley
Postby micksulley » Tue Jul 03, 2018 1:52 pm
Thanks for your reply, your updated file does exactly what I want, but I still cannot reproduce it myself.
I'm not sure what you mean by the bottom face for the through hole. I have selected the inside surface of the hole from underneath, which has the same effect as before, I have selected the bottom edge of the hole, but that does nothing. Can you explain what you mean by the bottom face?
How do you select all of the holes? I see in your file that both operation have only one entry in Base Geometry, but they operate on all of the holes. How?
Cheers
Mick
Postby chrisb » Tue Jul 03, 2018 3:06 pm
To investigate you open an existing model, edit a path operation and open the Base Geometry tab. There you have a list of faces or other geometry. Select an item from the list and it will highlight in 3D view.
micksulley
Postby micksulley » Tue Jul 03, 2018 6:27 pm
Thanks Chris, now I've got it! I had assumed that to create the hole cut operation I had to select the hole, just hadn't realised I could select the face and use the Process Holes & Process Circles check boxes. Also your tip about selecting the geometry makes things a lot clearer.
Mick
sliptonic
Postby sliptonic » Tue Jul 03, 2018 7:03 pm
Cheers
Mick
I'm not selecting the edge of the hole but the entire bottom face. The profile from face options can be set to process holes and circles but not the outside perimeter of the face.
