fillet on curved intersections
Hi all,
I am trying to define an enclosure as the intersection of a rectangular cuboid and two cylinders, and I would like to add fillets to all edges, except four.
However, freecad does not allow me to: even if the edges/faces are selected, and I choose "Fillet" from the menu, I get the "Select an edge, face or body from an active body." message, but I can't activate the body, because as soon as I try to select an edge, the top-level object, a common, will become active.
I have also tried making the cylinder as a surface of revolution, or taking it from the standard objects in the Part workbench, but that does not change the situation.
In any case, I would appreciate, if someone could shed some light on the problem. I am quite sure I miss something totally trivial.
Thanks,
Zoltán
OS: Ubuntu 18.04 LTS
Version: 0.17.13522 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.15rc1
OCC version: 7.2.0
Thanks,
Zoltán
Build type: None
OCC version: 7.2.0
- Screenshot from 2018-07-08 11-59-20.png (26.82 KiB) Viewed 1781 times
- test2.fcstd
- (26.63 KiB) Downloaded 26 times
Re: fillet on curved intersections
Hi Zoltán, welcome. You have probably used the PartDesing fillet which works only inside of a body, which you have left when you applied the Part->Common operaton. Use the Part Fillet instead.
I forgot: For Boolean Common you can use 3 elements as well. That saves you one common operation and one nesting level.
Greetings Chris,
Indeed, that was the problem. Thanks for the clarification!
Zoltán
Zoltán
Hi zvoros
It seems to me that during the comun operation you took out the object of the body, so you can no longer use Partdesign, if you take Part Wb, filet works
Competitors than me, will tell you how to stay in the body
- chocolat.JPG (13.52 KiB) Viewed 1767 times
Hello Zoltán,
Your test model could be done more efficiently.
You made three separate PartDesign bodies, then you left the PartDesign workbench and used the Part workbench. You didn't need to leave the PartDesign workbench: there is a PartDesign Boolean feature that would have allowed you to end up with a single Body and stay in PartDesign.
But you could also have made it in a single PD Body with only 2 sketches, one Pad and one Pocket. (meme2704: try to do better in v0.16 )
- test2_singlePDBody_nc1.fcstd
- (28.16 KiB) Downloaded 38 times
- test2_PDBoolean_nc1.fcstd
- (34.8 KiB) Downloaded 34 times
mais je l'ai fait en v0.17 But i tray(meme2704: try to do better in v0.16 )
10mn later, in V0.16
Where is the trap
and I did not get lost in the skirts of the female bodies
- chocolat1.JPG (17.32 KiB) Viewed 1715 times
Normand,NormandC wrote: ↑Sun Jul 08, 2018 3:45 pm Hello Zoltán,
Thanks for the hints, and extra thanks for the corrected freecad files!
