[Issue #3541] Hole feature does not work correct if sketch is not parallel to main planes
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Postby babaroga » Sat Jul 14, 2018 11:26 am
I was drawing some model recently and find a bug with Hole feature. If sketch is not parallel with one of main planes, diameter of hole is calculated wrong.
I made sketch with one corner at 30 degrees and another on 45 degrees compared to ZX plane.
Then I made a 20mm pad and apply sketches at three sides. I made used a Hole feature on all of them with same parameters. Diameter 10mm and depth 25mm. You can see result on following screenshot. Sketches are visible to show how much they defer. All circle diameters on sketches are 10mm.
On following screenshot you can see dimensions I get.
As you can see, dimensions of holes are calculated as
sin(angle)*diameter
sin(45)*10 = 7,0710
sin(30)*10 = 5
Same behavior I noticed on two Windows boxes with 0.17.13522 and 0.18.13976 from download section
My freecad is :
OS: "Manjaro Linux"
Version: 0.18.14083 (Git)
Hash: 07d1abb387c6b62093375fa7df99c92f2aaacda0
Python version: 2.7.15
Qt version: 5.11.1
Coin version: 3.1.3
OCC version: 7.2.0
Hole feature bug.FCStd
(35.59 KiB) Downloaded 33 times
DeepSOIC
Re: Hole feature does not work correct if sketch is not parallel to main planes
Postby DeepSOIC » Sat Jul 14, 2018 11:48 am
Confirmed...
OS: Windows 8
Version: 0.18.13935 (Git)
Hash: cb133767464337e4b5c8589a1fe33b4d7dad7721
Python version: 2.7.14
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
eivindkvedalen wrote:ping
Postby chrisb » Sat Jul 14, 2018 11:50 am
Confirmed on MacOS as well. Surprisingly the length is not affected:
Bildschirmfoto 2018-07-14 um 13.48.42.png (26.04 KiB) Viewed 1150 times
babaroga
Postby babaroga » Sat Jul 14, 2018 11:58 am
Should I file a Bug on tracker?
DeepSOIC
Postby DeepSOIC » Sat Jul 14, 2018 12:20 pm
Had a quick glance through the code. It looks like the problem might be somewhere here:
https://github.com/FreeCAD/FreeCAD/blob ... e.cpp#L980
        /* Compute xDir normal to zDir */
        if (std::abs(zDir.Z() - zDir.X()) > Precision::Confusion())
            xDir = gp_Vec(zDir.Z(), 0, -zDir.X());
        else if (std::abs(zDir.Z() - zDir.Y()) > Precision::Confusion())
            xDir = gp_Vec(zDir.Y(), -zDir.X(), 0);
        else
            xDir = gp_Vec(0, -zDir.Z(), zDir.Y());
The comment says xDir vector is being constructed, perpendicularly to zDir vector. That doesn't look like a valid way of constructing one.
tanderson69
Postby tanderson69 » Sat Jul 14, 2018 2:59 pm
I think it is valid, as I have seen something like this inside occ code. I agree it looks ugly. I have done it using dot and cross products, but the code isn't much better if at all.
My guess is the output vector just needs to be normalized.
DeepSOIC
Postby DeepSOIC » Sat Jul 14, 2018 3:31 pm
Did some tests, the result is indeed perpendicular. So I guess we have a fix proposal?
tanderson69
Postby tanderson69 » Sun Jul 15, 2018 3:27 pm
I didn't test anything, I was just giving an idea to someone who stays up with freecad development.
eivindkvedalen
Postby eivindkvedalen » Sun Jul 15, 2018 4:32 pm
        else
This code works, but I'm unsure if this is the right thing to do. Could you please try to hard-code xDir to be (1, 0, 0), and see if that helps?
Eivind
eivindkvedalen
Postby eivindkvedalen » Sun Jul 15, 2018 4:33 pm
Yes, please file a bug report, so we don't forget about this. Please also refer to this thread in the report.
Eivind
