Body invisible after deleting Part container
Postby chrisb » Sun Jul 15, 2018 3:26 pm
In the attached file there is a Part container with a body inside. The cube inside the body is visible. When I delete the outer Part container I say "no" to the question if I want to delete the contents too. That operation leaves Body with its contents.
However, the Body is invisible, whether I toggle it or not. The same holds for all features if the body is more complicated. The only solution is to save and reload the file.
Did I miss something?
HiddenBody.FCStd
(6.2 KiB) Downloaded 15 times
wandererfan
Re: Body invisible after deleting Part container
Postby wandererfan » Sun Jul 15, 2018 3:39 pm
FWIW, I've had seemingly random problems with toggling visibility with the spacebar. Sometimes going in to the View tab in PropertyEditor works better.
DeepSOIC
Postby DeepSOIC » Sun Jul 15, 2018 3:58 pm
Clearly a bug. I can reproduce.
Another "fix" is to create a new 3d view, and close the old one.
NormandC
Postby NormandC » Sun Jul 15, 2018 4:29 pm
It's the same issue as when creating a PartDesign Boolean, then deleting it. The Body that was used in the Boolean is no longer visible; the only workaround is to create a new 3D view.
Pre-selection/selection highlighting is also out of whack where Bodies and Part containers are concerned. It works, it doesn't, it works, it doesn't, with no logical reason why... Very confusing.
Postby chrisb » Sun Jul 15, 2018 5:04 pm
Should I create a ticket for this (reproducible) one?
NormandC
Postby NormandC » Mon Jul 16, 2018 6:36 pm
IMO yes.
Postby chrisb » Mon Jul 16, 2018 11:42 pm
Site Admin
Postby wmayer » Fri Sep 21, 2018 1:13 pm
Postby chrisb » Fri Sep 21, 2018 2:06 pm
Works flawless, thank you.
freedman
Postby freedman » Fri Sep 21, 2018 2:29 pm
After deleting the Part container I created a new one and the cube shows up.
