Reloading Python code without restarting the FreeCAD
project4
Postby project4 » Tue Jul 17, 2018 9:26 am
Hi guys,
I'm trying to help with a WorkBench development written in Python.
Is there a way to reload python code that belongs to the WB without the need to restart the whole FreeCAD application?
Switching to another WB and back didn't help :(
Thanks.
microelly2
Re: Reloading Python code without restarting the FreeCAD
Postby microelly2 » Tue Jul 17, 2018 10:15 am
force a reload in the Activatewd method of your command
		Gui.doCommand("import " + modul)
		Gui.doCommand("import " + self.lmod)
		Gui.doCommand("reload(" + self.lmod + ")")
                Gui.doCommand(self.command)
project4
Postby project4 » Tue Jul 17, 2018 10:25 am
Thanks, will try.
triplus
Postby triplus » Wed Jul 18, 2018 9:43 am
Usually doing:
reload(SomeModule.py)
Works just fine. That is when you changed code in SomeModule.py and it was already imported.
project4
Postby project4 » Wed Jul 18, 2018 9:57 am
Thanks!
Jee-Bee
Postby Jee-Bee » Wed Jul 18, 2018 11:26 am
Usually doing:
i remember that is don't work out of the box with py3...
christi
Postby christi » Sun Mar 24, 2019 9:37 am
Any ideas how reloading modules works with python 3 ?
christi
Postby christi » Sun Mar 24, 2019 9:50 am
This works with Python 3:
reload(MyModule)
but it does not work, if you have added your module to the GUI:
FreeCADGui.addCommand('MyModule', MyModule())
The solution can be creating a sub class that is called in the MyModule class
Postby chrisb » Sun Mar 24, 2019 10:07 am
I use sucessfully:
import someModule
from importlib import reload
reload(someModule)
steve123
Postby steve123 » Thu Feb 06, 2020 4:18 pm
It would be handy for debugging if there was a button somewhere (or maybe just a "developer" menu item) that would allow you to force FreeCAD to reload a module(s).
