Modelling trees with cfd
Moderator: oliveroxtoby
thschrader
Postby thschrader » Tue Jul 17, 2018 1:29 pm
Hello everyone,
I want to calculate the pressure-distribution on my little house.
But the house is surrounded by trees. The trees have an effect on the
wind-flow, but it makes no sense to model the trees as solids.
I found this article
https://pdfs.semanticscholar.org/a0e6/9 ... fea0e1.pdf
They use darcy-forchheimer law for simulating the windbreak-effect of rows of trees.
Idea: use the porous-zone dialog in the cfd-wb.
But how must I interpret the input-dialog?
Is d=mu/k and f=1/k1 ?
What does the principal-direction mean?
When I estimate the „porosity“ k1 of a tree with 0,5, f=2.0. Is that right?
The vector e2 is missing in porosityProperties-dict.
I set up a turbulent test case, the „tree“ is the pink porous zone. I set the
turbulence-intensity to 15%, so I neglected the linear term in the darcy-forchheimer law.
Which gives zero for d in input dialog. Correct?
Comments welcome
Thomas
oliveroxtoby
Re: Modelling trees with cfd
Postby oliveroxtoby » Tue Jul 17, 2018 2:02 pm
Hello everyone,
In this notation, f = 2/k1 and d = 1/k.
One can have anisotropic drag in which the coefficient is different in different directions. Then the principal directions are orthogonal directions in which there is no rotation (i.e. drag parallel to velocity) - e.g. normal and parallel to a screen of tubes. If the coefficients are the same in each direction, they are irrelevant.
No, I don't think so; k and k1 in this formula appear to be permeabilities, not porosities.
No, it is not necessary. OpenFOAM calculates it orthogonal to the other two.
I don't think d should be ignored...
