Arch wall bug
ikua
Arch wall bug
Postby ikua » Fri Jul 27, 2018 12:20 pm
Hello!
It seems that arch wall is not able to work with big angles, 170 degress for example.
how to check:
1. draw a dwire in one plan with 90 angle (two edges)
2. make a wall with the dwire
3. edit the dwire an make the angle bigger (closer to a straight line)
4. at some point you get the message:
DraftGeomUtils: unable to bind wires
Error: Invalid base object
and the wall stops to get recalculatet.
Tried in 0.17 Version and also in one 0.18
OS: Windows 7
Version: 0.18.13959 (Git)
Hash: 2f18182b6dff87f8857787c854e39ca4d441f993
Python version: 2.7.14
OCC version: 7.2.0
meme2704
Re: Arch wall bug
Postby meme2704 » Fri Jul 27, 2018 12:54 pm
Hi
I do not see it, maybe you have just said the coincidence of the summit
ikua
Re: Arch wall bug
Postby ikua » Fri Jul 27, 2018 1:06 pm
see attached file. Wall001 and Wall002 are based on dwire with big angles.
if you change dwire001 to a smaller angle suddenly the wall appears.
wall problem.FCStd
(13.67 KiB) Downloaded 12 times
NormandC
Re: Arch wall bug
Postby NormandC » Fri Jul 27, 2018 1:24 pm
If I mark the document for recompute then recompute the document, Wall001 and Wall002 are repaired.
OS: Ubuntu 18.04.1 LTS
Version: 0.17.13522 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
Locale: French/Canada (fr_CA)
wall problem_fixed_nc1.FCStd
(20.88 KiB) Downloaded 10 times
NormandC
Re: Arch wall bug
Postby NormandC » Fri Jul 27, 2018 1:28 pm
I can't reproduce.
meme2704
Re: Arch wall bug
Postby meme2704 » Fri Jul 27, 2018 1:30 pm
it's the same for me :!:
yorik
Site Admin
Re: Arch wall bug
Postby yorik » Fri Jul 27, 2018 7:39 pm
Works for me too... Any error message in the console?
ikua
Re: Arch wall bug
Postby ikua » Sat Jul 28, 2018 7:05 pm
for me it does not work. Strange.
error message:
DraftGeomUtils.connect: unable to connect edges
(<Line object>, ' ', Vector (400.0, 300.0, 0.0), ' ', Vector (1000.0, 300.0, 0.0))
(<Line object>, ' ', Vector (970.4511880673244, 304.46535856890773, 0.0), ' ', Vector (1526.044815997012, 132.62055571246242, 0.0))
(<Line object>, ' ', Vector (400.0, 500.0, 0.0), ' ', Vector (1000.0, 500.0, 0.0))
(<Line object>, ' ', Vector (1029.5488119326756, 495.53464143109227, 0.0), ' ', Vector (1585.142439862363, 323.68983857464696, 0.0))
wall problem.gif (85 KiB) Viewed 385 times
