fem analisys on carbon tube specs?
josheeg
Re: fem analisys on carbon tube specs?
Postby josheeg » Thu Aug 02, 2018 5:00 am
I was able to get it to work with polygons not circle maby circle and auto settings do not work with fem well.
josheeg
Postby josheeg » Thu Aug 02, 2018 5:19 am
Here is the error with a tube and fem on the ends that are octagons.
I will include the file the error and the pic
windows 10 freecad .17
octogonendswithcirculartubegmesh.FCStd
(71.1 KiB) Downloaded 10 times
0.0: We are going to start ...
0.0: Start Gmsh ...
1.5: Gmsh had warnings ...
1.5: Warning : :-( There are 3 intersections in the 1D mesh (curves 24 20 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 27 28 30) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 16 20 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 27 29 28) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 18 20 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 30 29 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 12 16 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 30 32 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 14 16 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 31 30 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 12 14 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 32 31 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 24 12 25) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 10 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 32 34 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 33 32 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 34 33 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 27 28 34) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 35 34 27) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Warning : :-( There are 3 intersections in the 1D mesh (curves 27 28 35) Warning : 8-| Gmsh splits those edges and tries again Warning : Surface 12 consists of no elements Error : Self intersecting surface mesh, computing intersections (this could take a while) Error : Could not open file 'intersect.pos' Warning : Volume 1 consists of no elements Warning : Surface mesh: worst distortion = -1.53331e+14 (avg = -9.70701e+11, 5 elements with jac.
1.5: Gmsh done!
HarryvL
Postby HarryvL » Thu Aug 02, 2018 6:09 am
josheeg wrote:
Thu Aug 02, 2018 4:37 am
I am running windows 10 and freecad 0.17 and the max and min element sizes are 0.0 both of them that equals auto. But maby selecting the circle part and putting a force on it. does not mesh in gmesh ok because it is not closed manafold correctly. The outside identified or something?
Here is the file.
0.5" circle extruded by 24" in
@josheeg, explicitly setting the maximum element size to 10mm or below will make it work:
josheeg
Postby josheeg » Thu Aug 02, 2018 4:49 pm
Wow now things are going :D thanks.
Ok one more question I am using win 10 freecad 0.17
I get a error when I try to do analysis on a assembly2 assembly of tubes the id is 0.4" in and the connector od is 0.4in".
HarryvL
Postby HarryvL » Thu Aug 02, 2018 6:20 pm
@josheeg, please post the FC file. The previous file had volume elements. No OD and ID.
josheeg
Postby josheeg » Fri Aug 03, 2018 4:44 am
Ok assembly2 requires different parts and then the assembly file so I will send the parts and the assembly2 workbench file.
This is a carbon fiber tube frame from dragon plate allred in NY state.
threaded_tube_connector.FCStd
(14.78 KiB) Downloaded 11 times
pcft__5_4_24_in.FCStd
(10.83 KiB) Downloaded 10 times
pcft_5_4_48_in.FCStd
(10.77 KiB) Downloaded 11 times
pcft_5_4_72_in.FCStd
(10.81 KiB) Downloaded 12 times
pcft_5_4_98_in.FCStd
(10.82 KiB) Downloaded 10 times
josheeg
Postby josheeg » Fri Aug 03, 2018 4:45 am
the skeleton frame is the assembly and I can only add so many files per post so this and the previous one.
THanks. :mrgreen: :geek: :ugeek:
cube_v_threaded_1_in.FCStd
(38.3 KiB) Downloaded 10 times
skeleton frame.FCStd
(207.53 KiB) Downloaded 11 times
HarryvL
Postby HarryvL » Fri Aug 03, 2018 10:57 am
@josheeg,
File "skeleton frame" does not contain an Analysis Object or a Mesh. Just for demonstration purpose I combined 1 cube, 1 connector and 1 tube into a Boolean Fragment (mode Compsolid) to show that you can actually mesh and analyse the assembly:
The FC file for this (with meshes deleted for reasons of size) is also attached:
(221.47 KiB) Downloaded 9 times
A few words of caution: meshing the whole assembly with 3D elements will probably get you in to trouble (time and/or memory)
Depending on what you want to achieve with the analysis, I would take an old-fashioned engineering approach. For example, if you are interested in the deformation or stress int the connections then first model tubular frame as beams with rigid connections and apply the resulting internal forces as external loads on the connections ... i.e. apply the "expensive" elements where they matter (no different from how NASA managed to design the Saturn Rockets in the 60s :D )
josheeg
Postby josheeg » Sun Aug 05, 2018 5:47 pm
I am trying to run a analysis on this frame it is taking a long time at max size .1 in but .05 is very long and .1 is the thickness of the tube in 3d.
(10.82 KiB) Downloaded 9 times
(10.83 KiB) Downloaded 9 times
(14.78 KiB) Downloaded 10 times
frame_VTOL_Plane_union_analysis.FCStd
(227.32 KiB) Downloaded 10 times
josheeg
Postby josheeg » Sun Aug 05, 2018 5:49 pm
here is the photo win 10 freecad 0.17
running after error running in auto running at .1" in max size. tube thickness is .1" so maby .05" would be needed but realy slow.
frame analysis.png (177.01 KiB) Viewed 275 times
