Diameter dimensioning
maker
Postby maker » Sat Jul 28, 2018 11:01 am
Hi all,
I started a new thread in german language forum under
https://forum.freecadweb.org/viewtopic.php?f=13&t=29982
German title: TechDraw workbench Durchmesserbemaßungen
Translated: TechDraw workbench dimensioning of diameters
This because I identified 3 problems with the TechDraw workbench, I actually have.
Generally speaking:
There is no editable text for dimensioning of diameters
The problems are:
  • Problem 1:dimensioning of diameters in correct form according to e.g. technical standards
  • Problem 2: Replacement of dimensioning text (Symbol for diameter Ø 6 replaced by screw thread designation M 6)
  • Problem 3: dimensioning text for nominating tolerances
Is there any solution in FC 0.17 Rev 13522 now?
Is there any reliable and easy-to-manage solution in prospect?
Kind regards
wandererfan
Re: Diameter dimensioning
Postby wandererfan » Sat Jul 28, 2018 1:55 pm
[There is no editable text for dimensioning of diameters
Problem 1: if the dimension text is aligned with the vertical or horizontal axis of the circle, it will be displayed in the traditional form. If the text is at an oblique angle, the dimension text will be displayed as a Leader. Note there is a bug in the positioning of the text in the aligned case. Does Diameter displayed as Leader violate standards?
Problem 2: this is coming in v0.18
Problem3: this is on the TODO list, but I'm not sure when it will be implemented.
From v0.18 development environment:
Jee-Bee
Postby Jee-Bee » Sat Jul 28, 2018 2:06 pm
I want to add something for problem 2.
Add the posibility to flip the arrow's from insine to outside.
Jee-Bee
Postby chrisb » Sat Jul 28, 2018 2:32 pm
A workaround for the tolerances is to add them as a SVG symbol.
Bildschirmfoto 2018-07-28 um 16.32.43.png (12.16 KiB) Viewed 901 times
align.svg
(3.14 KiB) Downloaded 157 times
M6.FCStd
(8.64 KiB) Downloaded 23 times
wandererfan
Postby wandererfan » Mon Jul 30, 2018 12:59 pm
They are supposed to be smart enough to flip themselves. I must have broken something while fiddling :oops: .
Jee-Bee
Postby Jee-Bee » Mon Jul 30, 2018 2:10 pm
Would it be possibel to add a manual override (for example RMB >> flip arrows)?
maker
Postby maker » Wed Aug 01, 2018 9:27 pm
I have created a ticket.
Please look here: https://www.freecadweb.org/tracker/view.php?id=3549
Title: Enable editable diameter dimensioning text (e.g. specification of thread, tolerances)
Kind regards.
wandererfan
Postby wandererfan » Thu Aug 02, 2018 1:22 pm
In 0.18, you can do this:
Are you looking for full text formatting? Subscripts, superscripts, bold, italic, etc?
Postby chrisb » Thu Aug 02, 2018 5:47 pm
It would be great if the configurable diameter symbol (default = ⌀) would be part of the format, and not of the value. If the format would be something like
⌀ %.4f
then it could be easily changed to
M %.4f ± something
staying parametric if the diameter changes.
