Numerical input on object creation
zbigg
Postby zbigg » Fri Aug 17, 2018 1:04 pm
hi,
Re Arch WS: Is it possible to enter required eg length while creating a wall ?
I mean: I stretch the wall along some /SHIFT locked/ constraint/axis and need to just enter a number, without jumping between panels, panes and input fields?
cheers,
meme2704
Re: Numerical input on object creation
Postby meme2704 » Fri Aug 17, 2018 1:52 pm
Hi
I do not understand the question: there are 2 ways to create 1 wall
-input the coordinates of the starting point (X, Y, Z) then long, width, height of the wall
or
- you draw the trace of the wall, then width and height of the wall
zbigg
Postby zbigg » Fri Aug 17, 2018 1:55 pm
Just answering: I draw the trace /start point/ then want to enter just the length.
Direction/axis has been locked on start with <Shift> key.
Sketchup would be best reference.
cheers,
bejant
Postby bejant » Fri Aug 17, 2018 2:15 pm
zbigg wrote: Fri Aug 17, 2018 1:55 pm I draw the trace /start point/ then want to enter just the length.
Drag the cursor out of the 3D view.
Look at the panel on the left; a length can be entered from the keyboard.
zbigg
Postby zbigg » Fri Aug 17, 2018 2:46 pm
ok, it works partially. I wanted to have it on numerical block, here it does not work.
Btw its NOT best idea to lock axes with SHIFT when SHIFT produces also different codes when pressed alongside.
SO-if you need to draw a wall along X/Y of your UCS, you drag the wall from some point and want to input its length -
- with Shift already pressed you'll obtain rubbish instead of a numerical value.
This needs to be redesigned.
cheers,
bejant
Postby bejant » Fri Aug 17, 2018 9:03 pm
bejant
Postby bejant » Sat Aug 18, 2018 1:08 am
zbigg wrote: Fri Aug 17, 2018 2:46 pm I wanted to have it on numerical block, here it does not work.
I don't know what you mean here.
zbigg wrote: Fri Aug 17, 2018 2:46 pm Btw its NOT best idea to lock axes with SHIFT when SHIFT produces also different codes when pressed alongside.
Then after dragging the cursor out of the 3D view:
1. Stop pressing the Shift key, or
2. Stop pressing the mouse button, or
3. Stop pressing both the Shift key and the mouse button.
See my previous reply; I'll edit it after I post this one.
After pressing the Shift key, moving the Line in the direction I want (vertically in the screen grab) until the cursor is out of the 3D view, this is what it looks like for me:
So all I have to do next is key in the numbers I want and then press the Enter key.
OS: Ubuntu 16.04.5 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.14220 (Git)
Build type: None
Hash: 1d81fd66b84af9ef8330ba1f1f6d1c5d6443f0c4
Python version: 2.7.12
zbigg
Postby zbigg » Sun Aug 19, 2018 11:41 am
ok-got it, works as expected.
But same problem as pointed in thread: Opening height.
I key in eg: 121 and obtain 12,5cm instead. Dont make me to add 'cm' to the typed number :?
Units set to CM.
cheers,
