Hi bug in fem materials adding 0swhen tabbing to the next field. ??
josheeg
Postby josheeg » Mon Aug 20, 2018 4:45 am
[bug]freecad v 0.17 windows 10 release coppy of freecad when putting a value in fem material new more 0s appear after tabbing to the next field. Gui bug or operator error? :geek: :ugeek: [/bug]
Re: Hi bug in fem materials adding 0swhen tabbing to the next field. ??
Postby Kunda1 » Mon Aug 20, 2018 10:18 am
Hover over the [bug] label to see how it's used. It's used to reference ticket numbers in our bug tracker. 😉
You should also probably be using 0.18dev if you want to benefit from a more up to date FEM work bench. Please read the guidelines on how to properly post asking for help for the devs to help you.
bernd
Postby bernd » Mon Aug 20, 2018 4:17 pm
@josheeg
- I can not reproduce this.
- would you try in 0.18 dev?
- would you be more specific ... which gui fild? Did you use a new file or an example or whatever? just write down any step starting with start FreeCAD
josheeg
Postby josheeg » Wed Aug 22, 2018 5:04 pm
Bug Freecad fem material
windows 10
freecad 0.17 release
will try 0.18 but it is dev
create a cube in part 1”
go to fem workbench
analysys
add material
density I put a decimal point in after 1700. and 3 zeros apeared
youngs model number I set to 3333333. psi
modulus I set to .2
I save the material and it doesn't record all the numbers maby I have to save it as a different file.
that seemed to hold.
