[SOLVED] view solid colors in technical drawing
jango
Postby jango » Mon Aug 27, 2018 4:12 am
Is possible to represent views of a solid in a technical draw that preserve the object original colors? something like this:
wandererfan
Re: view solid colors in technical drawing
Postby wandererfan » Mon Aug 27, 2018 1:32 pm
Yes, but it isn't perfect or easy. You can apply an SVG hatch using the Solid pattern to any Face in the drawing Image TechDraw_Hatch.
The bad news. 1) You have to apply the hatch to each Face individually. 2) the Face finding algorithm in TechDraw is imperfect, so you might have an area that isn't recognized as a Face.
jango
Re: [SOLVED] view solid colors in technical drawing
Postby jango » Tue Aug 28, 2018 3:20 am
Not a perfect and easy solution, but function for now.
yorik
Site Admin
Postby yorik » Tue Aug 28, 2018 1:46 pm
Note that using an Arch Section plane + Techdraw Arch View set in "Solid" rendering mode will produce colored views like the example above. But it is pretty buggy and will fail miserably with complex objects with a lot of curves...
@wandererfan, the current TD view already fills faces with white, right? An easy trick/fix would be to allow for the user to change this for another color...
wandererfan
Postby wandererfan » Wed Aug 29, 2018 12:40 am
Yes, solid white fill unless there is a hatch assigned to the face. Adding a Property::Color to the ViewProvider would be an improvement over using a solid hatch on each face.
But somebody is sure to ask for different colors on different faces, no? ;)
jango
Postby jango » Thu Aug 30, 2018 3:33 pm
I've a suggestion: a technical draw is a very important tool for make easy understandable the manufacturing process and quality control of a large variety of products whose representations will be very different. In this sense we need mechanism to modify those representations: make drafts in it, modify "with one click" properties of individual or groups of points, lines, faces or bodies, texts. In example the following cases:
1. A gear arrangement draw have too much information, for simplify views we hide or paint white a group of lines and sketch some conventions.
2. Drawing fabric products we use colors in surfaces to differentiate distinct layers of materials and highlight individual lines that represent joints.
3. In large part lists commonly we need to modify a specific text box without the needing of recompute the whole table.
It's a very useful software! :D just pay more attention to the technical draw module. The examples bellow:
Postby Kunda1 » Fri Aug 31, 2018 7:57 am
Does this Feature Request merit a ticket ?
wandererfan
Postby wandererfan » Fri Aug 31, 2018 10:59 am
Probably. But I'm not sure what the Feature Request actually is; easier color drawings, hide individual lines in the drawing, hightlight individual lines, don't recompute on text changes....
Don't see all that being done as one work package.
Postby Kunda1 » Fri Aug 31, 2018 1:07 pm
I'll split them in to 4 tickets then.
Postby Kunda1 » Fri Aug 31, 2018 1:15 pm
