Cura Plugin
lemonbug
Cura Plugin
Postby lemonbug » Mon Aug 27, 2018 4:39 pm
Hi-
I just got a 3D printer and use Cura 3.4.1 to prep my files. I just installed the FreCAD plugin but I am not sure how to get it working. I have tried to open FreeCAD files directly in Cura but it says "Failed to load". Does anyone have experience with this? I am on the latest version of OSX.
Thanks, j
OS: Mac OS X
Version: 0.17.13519 (Git)
Branch: (HEAD detached at 1a8b868)
Hash: 1a8b868018f45ea486c0023fdbfeb06febc1fb89
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
TheMarkster
Re: Cura Plugin
Postby TheMarkster » Mon Aug 27, 2018 5:03 pm
Hi-
Thanks, j
OS: Mac OS X
Qt version: 5.10.1
OCC version: 7.2.0
I have tried the FreeCAD plugin for Cura, but was unhappy with the results at the time. It could be the plugin works better now than it did when I tried it. (I don't think it was respecting visibility / invisibility, and so boolean operations were being ignored.) But even if it works properly there are still times when I do not wish to print every object in my document.
My current method is to select the object I want to print, export to stl via file export menu, then import the stl into Cura.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
lemonbug
Re: Cura Plugin
Postby lemonbug » Mon Aug 27, 2018 6:06 pm
Hi. Thanks. I was just told it is not supported for OSX at this time. No biggie, would just save me a step.
TheMarkster
Re: Cura Plugin
Postby TheMarkster » Mon Aug 27, 2018 6:37 pm
If you look in the tools -> addon manager, there is a workbench called cura_engine. I've never tried it.
lemonbug
Re: Cura Plugin
Postby lemonbug » Mon Aug 27, 2018 6:45 pm
Got it installed now. Will look up documentation. Thanks
Re: Cura Plugin
Postby chrisb » Mon Aug 27, 2018 8:46 pm
The Cura_engine didn't work in 0.16 properly and hasn't been updated as far as I know. Don't expect too much, but if you get it going, report back.
nemesis
Re: Cura Plugin
Postby nemesis » Tue Aug 28, 2018 8:30 am
Have a look here I manage to make it work on OSX a while ago, but honestly it is far quicker to export in stl and manage everything in Cura.
It could be intersting to have a Slicing Workbench if someone manage to get GCODE directly from CAD data and not the STL file. but you need a Firmeware onn your printer that manage Bspline, Marlin does. Should be possible to adapt some path workbench function if you have the skills ;)
Re: Cura Plugin
Postby chrisb » Tue Aug 28, 2018 9:49 am
The Path WB indeed approximates arbitrary curves and creates proper G2 and G3 commands.
lemonbug
Re: Cura Plugin
Postby lemonbug » Tue Aug 28, 2018 2:35 pm
Wasn't able to get it to do anything so I gave up after 30 minutes.
lemonbug
Re: Cura Plugin
Postby lemonbug » Tue Aug 28, 2018 2:36 pm
Thanks, just sticking to my SD card for now.
