Problem with recompute dimensions ;/
bridge
Postby bridge » Mon Sep 03, 2018 4:55 pm
Hello I have problem with recompute dimensions in Drawing Dimensioning , when using r.d radius arrow go to one point ?
Sugestion ?
Thank you for your help :)
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.14
OCC version: 7.2.0
Locale: Polish/Poland (pl_PL)
Re: Problem with recompute dimensions ;/
Postby chrisb » Mon Sep 03, 2018 8:54 pm
Drawing workbench and Drawing Dimensioning are outdated nowadays. TechDraw is in many ways much more advanced than the afore mentioned combination. Especially the recompute works much better. I would recommend to give it a try.
NormandC
Postby NormandC » Mon Sep 03, 2018 9:06 pm
I'm not certain of the nature of your problem. Did you add radius dimensions to different edges, then they all got switched to the same edge after a recompute?
Unfortunately, the author of Drawing Dimensioning stopped its development 2 years ago, and nobody volunteered to pick it up. I doubt that you will get help solving this issue.
On the other hand, when a fillet is the same in multiple places in a part, by common convention you only create one dimension and add "typical" or "typ." to the label, so you don't clutter the drawing view. So the dimension would read "R0.2 (typ.)" (with or without parenthesis)
Unfortunately, regarding dimensioning, it is still missing a lot of tools that Drawing Dimensioning offers. Hopefully they will get added in the future. That being said, I see nothing in bridge's screen capture that cannot be done already in TechDraw.
bridge
Postby bridge » Mon Sep 03, 2018 9:32 pm
Hello, I changed the dimension exactly 4.2 to 4.6 in the sketch and wanted to update and after this operation such an effect, all dimensions were on their own and the ones that dimensioned the rays came together in one place.
Tech draw, for example, has no possibility of inserting tolerances, how can I create a table in this WB and another additional advantage of DD. is that I can give the symbols of groove, welding, etc. Maybe there is some way I do not know because I'm a very beginner Freecad thank you very much for your help
Postby chrisb » Mon Sep 03, 2018 9:42 pm
...I can give the symbols of groove, welding, etc. Maybe there is some way I do not know
You can add additional symbols: https://forum.freecadweb.org/viewtopic. ... 17#p247117
bridge
Postby bridge » Mon Sep 03, 2018 10:07 pm
ok thank you, one more question where I can find a database of GDT symbols in svg format. GDT as WB does not work on me, gets an error message:
App::Document::recompute(): cyclic dependency detected
File "C:\Users\pawel\AppData\Roaming\FreeCAD\Mod\GDT\GDT.py", line 1171, in updateData
fp.circumferenceBool = True if (True in [l.Closed for l in fp.faces[0][0].Shape.getElement(fp.faces[0][1]).Edges] and len(fp.faces[0][0].Shape.getElement(fp.faces[0][1]).Vertexes) == 2) else False
<type 'exceptions.TypeError'>: argument 1 must be string, not tuple
File "C:\Users\pawel\AppData\Roaming\FreeCAD\Mod\GDT\GDT.py", line 1451, in createObject
obj = makeDatumFeature(self.textName, self.ContainerOfData)
File "C:\Users\pawel\AppData\Roaming\FreeCAD\Mod\GDT\GDT.py", line 834, in makeDatumFeature
makeAnnotation(ContainerOfData.faces, ContainerOfData.annotationPlane, DF=obj, GT=[])
File "C:\Users\pawel\AppData\Roaming\FreeCAD\Mod\GDT\GDT.py", line 1243, in makeAnnotation
obj.p1 = (obj.faces[0][0].Shape.getElement(obj.faces[0][1]).CenterOfMass).projectToPlane(obj.AP.PointWithOffset, obj.AP.Direction)
TypeError: argument 1 must be string, not tuple
NormandC
Postby NormandC » Mon Sep 03, 2018 10:20 pm
Quite a hassle though.
Postby chrisb » Tue Sep 04, 2018 4:36 am
You do this only if you really need it.
