FEM meshing doesn't generate volume elements
nquantum
Postby nquantum » Tue Sep 04, 2018 1:30 pm
It quite a while what is status of the issue "why sometime no volume?"
Me too I use Freecad 0.17 and someime no volume on create mesh. I notice that the smaller or fine the mesh size then usually no volume. Both Gmsh and Netgen. But if mesh is courses or big it can have volume.
Why? And good work around?
I will later add pictures.
EDIT: related topic https://forum.freecadweb.org/viewtopic.php?f=18&t=15328
bernd
Re: Why does FEM meshing doesn't generate volume elements in some cases
Postby bernd » Tue Sep 04, 2018 3:20 pm
Usually it is a problem of your geometry, means you should not add pictures but a FreeCAD file with your geometry.
nquantum
Postby nquantum » Tue Sep 04, 2018 4:09 pm
I see. Here is the file.
I design cnc and would like to see deformation of structure to know estimate how strong or weak point of each of design.
I hide other part only left "a001" for FEM. It is base for x-axis. I've try create mesh from whole body, all of them created no volume. So I try on x-axis only. I can create mesh with volume and can solve to show result only by Gmsh (use max value 0 or more than 50).
Netgen create no volume no matter max size is 10,100,1000,10000 coarse , fine , moderate.
So here it is. Coarse mesh can create with volume. Fine mesh no volume. On same shape. But for simple shape like couple of rectangles in tutorial no problem on both Netgen and Gmsh. What am I wrong?
PS. file is 2mb big cannot upload so I put in the google drive and here is link.
https://drive.google.com/open?id=1TFGZK ... FOGdd_Uvkq
netgen
gmsh way smaller
gmsh smaller
gmsh course1
UR_
Postby UR_ » Wed Sep 05, 2018 9:02 pm
To get reliable meshing results, you should provide model data following an improved quality standard.
What's this:
2018-09-05 22_54_18-FreeCAD 0.18.png (73.45 KiB) Viewed 658 times
nquantum
Postby nquantum » Sat Sep 08, 2018 2:20 am
What you mean by provide model data? You mean I must set some value or data something in Freecad? Or should I send new file? Or should I provide better picture like you in example u provided?
An I think I found cue, I've created self-intersect mesh from those round-rail with those rectangle block with hole. If I meshing them seperately then no problem. Once they together like the picture many time they have self-intersect mesh which produce no volume.
Maybe this cause of it? I try to find how the way to avoid and/or how to fix.
Pls also advice
that is I try to model
nquantum
Postby nquantum » Sat Sep 08, 2018 7:00 am
I want volume mesh for use in FEM module to see how strong structure
bernd
Postby bernd » Sat Sep 08, 2018 3:47 pm
As mostly UR_ is on the right track. Without the sleds your geometry meshes for me. Attached the file with geometry and meshes cleared. But the mesh still has some problems, see screen ...
cnc2-bernd1_cleared.FCStd
(124.24 KiB) Downloaded 10 times
nquantum
Postby nquantum » Sat Sep 08, 2018 3:59 pm
I'm sorry bernd, I don't understand what you try to tell me or want me do. Can you please tell me again? I've problem about geometry?
bernd
Postby bernd » Sat Sep 08, 2018 4:20 pm
If I use the geometry from your file but do not use the sleds which are on the rails, the geometry meshes fine for me with volumes. This is what _UR has shown on his screen. There is some problem with the sleds on the rails.
The question is, what exactly would you like to analyze? Depending on the answer you do not need the sleds and thus you can use your geometry without the sleds.
bernd
bernd
Re: FEM meshing doesn't generate volume elements
Postby bernd » Sat Sep 08, 2018 4:26 pm
Since this is not really related to the topic from the first post and the topic was years old, I made an own topic.
