Select what you want to see in the Document Tree
mlampert
Postby mlampert » Tue Sep 11, 2018 6:31 pm
As of last night the Document Tree widget has 3 options for what is being displayed:
* Only the currently active document
* All documents as it used to be
* Expand the active document and collapse all others
Due to the challenges and confusion by novice users the default behaviour has changed to only show the currently active document. If you want to change the behaviour, go to the menu "View" -> "Document Tree".
DeepSOIC
Re: Select what you want to see in the Document Tree
Postby DeepSOIC » Tue Sep 11, 2018 6:44 pm
nice!
Jee-Bee
Postby Jee-Bee » Tue Sep 11, 2018 6:59 pm
congrats @mlampert nice feature!!
pablogil
Postby pablogil » Tue Sep 11, 2018 9:36 pm
I like it!
It’s really a nice feature for newbies
Thanks!!
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Postby chrisb » Wed Sep 12, 2018 12:14 am
And for oldies as well.
Thanks!!
sliptonic
Postby sliptonic » Wed Sep 12, 2018 3:12 am
I think this is great! This and the task tab icon to indicate an active task will definitely help.
Nice work!
Postby chrisb » Wed Sep 12, 2018 2:23 pm
I used the new default visibility to switch between two models in order to compare the properties of some objects. I realized that the properties are not cleared when switching between documents.
It would be even greater, if the old selection and the display of the properties could be restored. Sorry for grabbing the whole hand when you gave us a finger.
freedman
Postby freedman » Wed Sep 12, 2018 3:14 pm
Thanks for pruning the tree.
easyw-fc
Postby easyw-fc » Wed Sep 12, 2018 3:16 pm
very good addition!
Is there a way to expand the tree of the document through python command?
furti
Postby furti » Wed Sep 12, 2018 3:45 pm
Very nice feature.
Thanks for adding :)
