Can't select a body
abasel
Can't select a body
Postby abasel » Wed Sep 12, 2018 8:40 pm
I have three bodies in my drawing. I can no longer select one of them. I can edit sketches in in but I cannot select faces on it to add more sketches. O have tried closing and re opening FreeCAD, tries toggling selections but nothing. The part with an issue is "BaseCover".
I am using
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/NewZealand (en_NZ)
Basev3.FCStd
(241.44 KiB) Downloaded 8 times
Willem
Re: Can't select a body
Postby Willem » Wed Sep 12, 2018 9:25 pm
Opening your file gives an error on sketch021.
Solve this problem.
Schermafdruk van 2018-09-12 23-19-28.png (59.57 KiB) Viewed 256 times
abasel
Postby abasel » Wed Sep 12, 2018 9:35 pm
I went in and could not see anything to cause an error. I recomputed and the esclamation went away. The origional issue still persists.
Basev3 - No Error.FCStd
(237.25 KiB) Downloaded 9 times
Mongrel_Shark
Postby Mongrel_Shark » Wed Sep 12, 2018 10:04 pm
I tried the latest file. Seems to be 2 bodys you can't interact with in the part view.. Basev3 and top.
Its only the last feature in both though. Both times its a pocket. Deleted pocket and used leftover sketch to make a new pocket and it got fixed.
Did you do anything different when you made these last 2 pockets? Can you re-create this "suspected bug"?
Posting my version details also in case there is a version related issue.
OS: Ubuntu 16.04.5 LTS
Version: 0.17.13541 (Git)
Build type: None
Python version: 2.7.12
Basev3 - Fixed.FCStd
(240.04 KiB) Downloaded 7 times
Willem
Postby Willem » Wed Sep 12, 2018 10:19 pm
Second point is that selectable must be true
Schermafdruk van 2018-09-13 00-15-06.png (205.48 KiB) Viewed 244 times
abasel
[SOLVED] Re: Can't select a body
Postby abasel » Wed Sep 12, 2018 11:22 pm
Awesome, that was it.
Thanks for all your help. I am very new at this and still learning heaps. I didn't realise that this setting was there. I must have accidentally changed it when making my last edit.
sgrogan
Postby sgrogan » Wed Sep 12, 2018 11:33 pm
Thanks Willem!
