Problem when exporting obj files
dcapeletti
Postby dcapeletti » Sun Sep 16, 2018 11:16 am
Hello,
I have a model in FreeCAD that I want to export to OBJ to be treated in Blender. To do this I select the whole model in 3D view with shift + b and drag the cursor to select everything. Then I export it all to .obj.
Then in blender I import the object, but the problem is that the object does not appear complete, some parts are missing.
I attach the files in a zip so you can review it.
How can I solve it?
Thank you ;)
import obj Blender.png (162.6 KiB) Viewed 124 times
Object selection.png (40.45 KiB) Viewed 128 times
All files.zip
(228.27 KiB) Downloaded 3 times
Re: Problem when exporting obj files
Postby chrisb » Sun Sep 16, 2018 1:18 pm
I hope this is an easy one: First I moved this to the help forum. (Having almost 200 posts you should have known). In this forum you have a red banner at the top with an IMPORTANT link. Follow it and find some interesting stuff. Among others there is the description of the most frequent errors, Where you can see that you should not select all in the tree, but only the last state of your model. When exporting a body you should not export the body plus something inside. Otherwise pockets can be missing, because they are closed by some other object.
Postby NormandC » Sun Sep 16, 2018 3:31 pm
@dcapeletti
Seriously? Again???
Problem to export to .obj
And this is exactly what I told him in his previous topic from 8 days ago!!! :roll:
Postby NormandC » Sun Sep 16, 2018 3:32 pm
Chris, I am certain that the zip archive is exactly the same as in the previous topic.
I vote for locking this topic as duplicate.
Postby chrisb » Sun Sep 16, 2018 5:48 pm
They are the same.
Postby wmayer » Sun Sep 16, 2018 5:53 pm
When exporting to a mesh file then only select
Body, Body001 and Body001 (Mirror #1) and nothing else. Important is to not select Pad and Pocket002 because this leads to duplicate triangles and then this might be recognized as errors in the data structure and will be removed.
