Writing a bug report, other platform testing ...
freedman
Postby freedman » Sun Sep 16, 2018 3:31 pm
The bug is essentially a problem with the Tree and Body control with the "Display properties" window open. Could we verify in other platforms?
Very simple to test:
Create a new file and a Body.
Right-click the Body in the tree and select Appearance, the "Display properties " opens, keep that window open.
Select Body in the tree and rename it.
That's where the problems starts on my Windows machine. When I hit Enter the Body text field does not close correctly, properties don't show, many different screen things don't work correctly.
I presume the programmers expect the Display properties window to be closed but there are no interlocks to guarantee.
Thanks
OS: Windows 7
Version: 0.18.14709 (Git)
Hash: faad5ea27301cb7af393a25d317c406d3098bafe
Python version: 2.7.14
OCC version: 7.2.0
Jee-Bee
Re: Writing a bug report, other platform testing ...
Postby Jee-Bee » Sun Sep 16, 2018 3:52 pm
At least post your version info!!
freedman
Postby freedman » Sun Sep 16, 2018 4:27 pm
Thanks Jee-Bee
GeneFC
Postby GeneFC » Sun Sep 16, 2018 4:28 pm
This happens in lots of situations. Did you watch Sliptonic's video on annoyances?
Not sure it is a bug in terms of function. May be a "bug" in terms of lack of notification to the user to close the active task before trying to do something else.
Gene
freedman
Postby freedman » Sun Sep 16, 2018 4:49 pm
I did watch it. I don't consider this just a nuisance issue, this essentially crashes the program because Bodies can't be named or renamed.
Postby NormandC » Sun Sep 16, 2018 5:12 pm
It would be useful if you could create a screencast... Writing "many different screen things don't work correctly" is not helpful at all.
The first time I create a new document and follow these steps, with the Appearance window open, I can type a new name for the Body, but when I hit Enter, the text is kept but the field remains active, and the Report view reports
Unhandled std::exception caught in GUIApplication::notify.
The error message is: basic_string::_M_construct null not valid
Once I close the Appearance window, the new name is kept, and I don't lose any functionality.
But, trying to repeat those steps again in the same document, hitting Enter now discards the new name. After I close the Appearance window, I can no longer rename the Body, but its View and Data properties remain visible, and FreeCAD seems to otherwise behave normally.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14727 (Git)
Hash: c6df59969bfb3ae2027e2b47ddd559852f6e9a4e
Python version: 2.7.15rc1
Locale: French/Canada (fr_CA)
freedman
Postby freedman » Sun Sep 16, 2018 6:25 pm
If an additional Body is created it can't be renamed at all once the issue of mention occurs. Properties view may be working correctly.
I never know how much response I will get so I get cryptic, I forgot this will be linked to any tracker report. I will try to be more specific. Not in a place where I can do a screencast.
Also, once the program gets in this error mode, renaming a Body is not allowed after closing all files (not the program) and opening a new file.
TheMarkster
Postby TheMarkster » Wed Sep 19, 2018 3:13 am
https://github.com/FreeCAD/FreeCAD/pull/1681
Edit: The exception is being thrown when a string is attempted to be initialized with 0. This 0 is being returned by a method used to get the name of the property that was changed (in this case, the property being the label of the tree object). The workaround is to check the return value of the method against 0, and if it's 0, we log the error, and exit the dialog. I'm not sure if closing it was absolutely necessary, but I figured it couldn't hurt.
    if (vp != Provider.end()) {
       //original code:  std::string prop_name = obj.getPropertyName(&prop);
        std::string prop_name;
        if (obj.getPropertyName(&prop)!=0){
        } else {
            Base::Console().Error("DlgDisplayPropertiesImp::slotChangedObject(): Error: obj.getPropertyName() failed.\n");
            this->reject(); //close the window
            return;
Postby wmayer » Wed Sep 19, 2018 7:24 pm
The crash is caused by assigning a nullptr to a std::string which causes a segfault on Windows but apparently raises an exception on Linux. All what needs to be done to fix this issue is assigning the returned value to a const char* which can be checked before continuing. If it's null nothing further needs be done (especially closing the dialog is not needed).
freedman
Postby freedman » Sat Sep 22, 2018 6:11 pm
I can leave the Display properties window open and no problem renaming Bodies. Fixed.
Thank you.
OS: Windows 7
Version: 0.18.14786 (Git)
Hash: 75acfe898f97d213647b0b93032287e48a31abfe
OCC version: 7.2.0
