Modelling for IFC export
This forum section is only for IFC-related issues
cadgiru
Postby cadgiru » Wed Sep 19, 2018 6:01 am
Hi
Have attached an FCstd file of some test objects.
Also here a screenshot of ifc file of same, imported to ifcViewer
There must clearly be some rules we have to adhere to when wanting to export to ifc?
Help is as always much appreciated
regards
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14727 (Git)
Hash: c6df59969bfb3ae2027e2b47ddd559852f6e9a4e
Python version: 2.7.15rc1
At2_RoofTest.fcstd
(20.68 KiB) Downloaded 19 times
paullee
Re: Modelling for IFC export
Postby paullee » Wed Sep 19, 2018 5:58 pm
I have little experience, just trying to use ifc recently...
and have similar result as you do ...
At2_RoofTest.ifc
(6.63 KiB) Downloaded 30 times
Screenshot from 2018-09-20 01-52-26.png (90.05 KiB) Viewed 876 times
OS: "Fedora release 27 (Twenty Seven)"
Version: 0.17.13541 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.6
Qt version: 4.8.6
Locale: English/HongKong (en_HK)
cadgiru
Postby cadgiru » Thu Sep 20, 2018 4:45 am
So far, my findings on this are a bit strange.
If geometry is modeled 'in place' , everything seems to be fine.
If Geometry is moved, strange things sometimes happen.
Have tried moving at these levels, and combinations of these:
* Defining geometry (like wire or similar)
* Extrusion or similar
* Arch object
Getting somewhat confused
regards
cadgiru
Postby cadgiru » Sun Sep 23, 2018 6:18 am
After doing some testing, it seems that extrude symmetric is not working with ifc export.
Changed Extrusions of previous shown elements from Symmetric to 'Normal' extrusion seems to fix the issue
Can anyone confirm this?
paullee
Postby paullee » Sun Sep 23, 2018 2:25 pm
Hi, can you advise your IfcOpenShell setup e.g. using IfcOpenShell-python for reference?
Thanks.
cadgiru
Postby cadgiru » Sun Sep 23, 2018 4:30 pm
Thanks.
How to ?
paullee
Postby paullee » Sun Sep 23, 2018 5:56 pm
Did you compile downloading the source from IfcOpenShell?
cadgiru
Postby cadgiru » Sun Sep 23, 2018 6:14 pm
The one running is downloaded from ifcopenshell, not compiled by myself. I sadly never got that to work.
bernd
Postby bernd » Sun Sep 23, 2018 6:45 pm
Compiling ifcopenshell is not difficault. which system are you on?
cadgiru
Postby cadgiru » Sun Sep 23, 2018 7:06 pm
Build type: None
