[SOLVED] Frequency Analysis - FEM: No nodes found in Frd file
EkaitzEsteban
Postby EkaitzEsteban » Fri Sep 21, 2018 2:43 pm
When I perform a frequency analysis, I edit the .inp file manually including in the frecuency step:
** At least one step is needed to run an CalculiX analysis of FreeCAD
** written by write_step_begin function
*STEP
*FREQUENCY, SOLVER=MATRIXSTORAGE
1,0.0,100000.0
I include SOLVER=MATRIXSTORAGE option for obtaining the mass and stiffness matrices (.mas) and (.sti) files as described in the calculix manual
http://web.mit.edu/calculix_v2.7/Calcul ... de206.html
However, when I run the analysis I get the following error in the report view.
FEM: No nodes found in Frd file.
Problem on frd file import. No nodes found in frd file.
FEM: No result object in active Analysis.
The files containing stiffness and mass matrices are correctly written but there is no simulation results.
I dont know, Am I doing something wrong?
Thank you!
EDIT: fandaL solution works! https://forum.freecadweb.org/viewtopic. ... 76#p257758
However there is a small bug. Frd and the rest of the files contains all the information but (N-1) modal frequencies are displayed in the FreeCAD GUI. Shall someone check this?
best regards,
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.14
OCC version: 7.2.0
Locale: Spanish/Spain (es_ES)
Jee-Bee
Re: [Problem] Frequency Analysis - FEM: No nodes found in Frd file
Postby Jee-Bee » Fri Sep 21, 2018 5:14 pm
I guess looking to the link it should be
*STEP
*FREQUENCY, MATRIXSTORAGE
1,0.0,100000.0
otherwise does it werks with default analysis??
fandaL
Postby fandaL » Fri Sep 21, 2018 8:01 pm
... Notice that the program stops after creating these files. No further steps
are treated. Consequently, *FREQUENCY, MATRIXSTORAGE only makes
sense as the last step in a calculation.
It seems that saving stiffness and mass matrices is taken as a separate step (last one) which does not calculate the analysis itself.
Try to add it as the last step. Previous step could be the frequency calculation as usual, e.g.:
*STEP
*FREQUENCY
5
** Fixed Constraints
*BOUNDARY
FemConstraintFixed,1
FemConstraintFixed,2
FemConstraintFixed,3
** Outputs --> frd file
*NODE FILE
U
*END STEP
** added step for saving mass and stiffness matrices
*STEP
*END STEP
EkaitzEsteban
Postby EkaitzEsteban » Sun Sep 23, 2018 4:52 am
*STEP
1,0.0,100000.0
It simulates correctly with default analysis.
EkaitzEsteban
Postby EkaitzEsteban » Tue Sep 25, 2018 9:57 am
*STEP
*FREQUENCY
5
*BOUNDARY
*NODE FILE
U
*END STEP
*STEP
*END STEP
Thank you fandaL, it works perfectly. Awesome!
seppelw
Re: [SOLVED] Frequency Analysis - FEM: No nodes found in Frd file
Postby seppelw » Thu Apr 30, 2020 10:29 pm
sorry, but I fo not understand what needs to be changed, I have the same error.
What does need to be deletedd and added at the end of the file?
Thanks a lot, Seppel
FEMMeshGmsh.inp.txt
(846.84 KiB) Downloaded 15 times
