[Solved] Error Loading Mesh Module in 018.14784 but loads correctly in 018.14575
Moderator: oliveroxtoby
Syres
Postby Syres » Fri Sep 21, 2018 4:23 pm
Firstly I'm really not sure if this should be a CFD WB specific forum issue or a general Help forum issue so Moderators please feel free to move it accordingly.
I initially downloaded and extracted FreeCAD version 018.14784 daily and ran a set of macros to prepare the Millennium Falcon case (which I know works fine on 018.14575) using the CFD WB from 7th September 2018 and as soon as I double-clicked the XOR Mesh it errored therefore knowing there's been some Py3/Qt5 changes I upgraded to the latest CFD WB (while keeping a copy of the old one elsewhere on my data area) and closed FreeCAD. On re-opening 018.14784 I repeated the exercise and the error remains:
Loading MeshPart module... done
Loading Mesh module... done
  File "C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\_ViewProviderCfdMesh.py", line 62, in setEdit
    taskd = _TaskPanelCfdMesh._TaskPanelCfdMesh(self.Object)
  File "C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdMesh.py", line 105, in __init__
    self.update()
  File "C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdMesh.py", line 150, in update
    setInputFieldQuantity(self.form.if_max, self.clmax)
  File "C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdTools.py", line 300, in setInputFieldQuantity
    q.Format = (12, 'e')
<type 'exceptions.TypeError'>: PyCXX: Error creating object of type class Py::MapBase<class Py::Object> from (12, 'e')
My concern is that as the error is with both the old WB and the new one, that it's a commit in FreeCAD 018 since 9th September 2018 (date of 018.14575) that is possibly the root cause. Luckily I have a workaround as I have a copy of the CFD WB from 7th September and FreeCAD 018.14575 which are a stable combination.
Full FreeCAD info is as follows, works correctly in:
OS: Windows 7
Version: 0.18.14575 (Git)
Hash: a624fee2c27bbbb869df6a8ce40438953a282a8c
Python version: 2.7.14
OCC version: 7.2.0
Errors in:
OS: Windows 7
Version: 0.18.14784 (Git)
Hash: ac21bcc35c56b360e03c646f5cfdcf15e5769717
OCC version: 7.2.0
I hope that's sufficient detail, thanks
John
oliveroxtoby
Re: Error Loading Mesh Module in 018.14784 but loads correctly in 018.14575
Postby oliveroxtoby » Fri Sep 21, 2018 8:42 pm
    self.update()
Hi John
Thanks for the careful report. Your assessment is correct - there was a change to the python API in the last few commits. The workbench has now been updated accordingly and should work with both the old and the new.
Syres
Re: [Solved] Error Loading Mesh Module in 018.14784 but loads correctly in 018.14575
Postby Syres » Sat Sep 22, 2018 10:10 am
Tests on both versions through to starting solver worked correctly using the updated workbench, thanks for the quick response.
I've had a look at the change you made and that helps me if I come across any errors in other workbenches or macros that I only use occasionally.
Thanks again
John
