Making a Face from makeWire()
greg_b
Postby greg_b » Fri Sep 21, 2018 11:41 pm
This is my first FreeCAD python script, but I'm having trouble getting a face made from a closed wire. Here is the script in question:
import FreeCAD, Draft, Part
wall_thickness = 4.0
length = 40.0
diameter = 100.0
verts = [(0,0,0),(0,wall_thickness,0),(length,wall_thickness,0),(length,0,0)]
outline = Draft.makeWire(verts,closed=True)
profile = Part.Face(outline)  # Things die here
solid = profile.revolve((0,diameter/2,0),(1,0,0),360)
But that dies on the line where I try to make a Face from a Wire, so that I can revolve it (eventually). The output in the "Report view" is:
File "C:/stuff/revolve_test.py", line 10, in <module>
<class 'Part.OCCError'>: Argument list signature is incorrect.
Supported signatures:
(face)
(wire)
(face, wire)
(surface, wire)
(list_of_wires)
(wire, facemaker_class_name)
(list_of_wires, facemaker_class_name)
(surface, list_of_wires)
...which would seem to indicate that I could feed Part.Face with a wire, which I would have thought would have been the output of makeWire. But I must be missing something. When I try type(outline), I get <type 'FeaturePython'>, which isn't real informative. The Python console prints it out as a <Part::Part2DObject>. I can take the output of the makeWire(), and use the "Revolve" button on the Part workbench to get the ultimate revolution I'm after, so the wire seems like it must be valid and closed. I'm probably missing something very basic.
FWIW, I was trying to steal ideas from: https://forum.freecadweb.org/viewtopic. ... 792#p37621 in my search for how to programmatically make a revolution.
Thanks!
Greg
OS: Windows 7
Version: 0.17.13515 (Git)
Branch: releases/FreeCAD-0-17
Hash: e17b340949b75a226cc7d89989b0aa238ccfc75f
Python version: 2.7.14
OCC version: 7.2.0
Chris_G
Re: Making a Face from makeWire()
Postby Chris_G » Sat Sep 22, 2018 7:25 am
Draft.makeWire() is a high-level tool, that creates a FreeCAD object : this is the DWire that appears in the Tree-View.
Its shape can be a Wire or a Face :
o1 = Draft.makeWire(verts,closed=False)
o1.Shape # is a wire
o2 = Draft.makeWire(verts,closed=True)
o2.Shape # is a face
So you have 2 options :
- you can keep on using Draft.makeWire() and use the "Shape" property of the object
profile = outline.Shape
solid = profile.revolve(FreeCAD.Vector(0,diameter/2,0),FreeCAD.Vector(1,0,0),360)
- or you can create only the wire (not a whole FreeCAD object) :
vecs = [FreeCAD.Vector(t) for t in verts] # convert tuples to vectors
vecs.append(vecs[0]) # to close the wire
wire = Part.makePolygon(vecs)
face = Part.Face(wire)
solid = face.revolve(FreeCAD.Vector(0,diameter/2,0),FreeCAD.Vector(1,0,0),360)
Part.show(solid)
damian
Postby damian » Sat Sep 22, 2018 7:54 am
Good morning:
Chris_G wrote: Sat Sep 22, 2018 7:25 am or you can create only the wire (not a whole FreeCAD object)
To make a face is the most frequent OCCT operation for me. I'm doing
face=Part.makeFace(wireList, "Part::FaceMakerBullseye")
Where wireList is a list of wires, and in consequence, the face could have holes.
greg_b wrote: Fri Sep 21, 2018 11:41 pm (list_of_wires, facemaker_class_name)
Others FaceMaker available are "Part::FaceMakerSimple" and "Part::FaceMakerChesse"
greg_b
[SOLVED] Re: Making a Face from makeWire()
Postby greg_b » Sat Sep 22, 2018 3:13 pm
Thanks everyone. I've now got a working script! It looks like I need to start diving into the difference between "high" level and "low" level commands/objects and how to tell one from the other (and figuring out what the difference between a line, edge, wire, and segment are, etc.).
Thanks,
Greg
mario52
Postby mario52 » Fri May 14, 2021 11:31 am
Hi
@Chris_G i make one little macro with your little macro
Part.show(face )
##solid = face.revolve(FreeCAD.Vector(0,diameter/2,0),FreeCAD.Vector(1,0,0),360)
##Part.show(solid)
elle est ici Create Face object using Edges intersections
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
