[Partially solved] Selected element identification in .inp file
EkaitzEsteban
Postby EkaitzEsteban » Mon Sep 24, 2018 10:53 am
I am trying to select a simple element (type C3D10) from Gmsh mesh for changing the material solely to the selected element.
Using the mouse, in the Selection View I can click and check the following elements (e.g.)
SimpleBox.FEMMeshGmsh.Elem0F1 (FEMMeshGmsh)
SimpleBox.FEMMeshGmsh.Elem42F1 (FEMMeshGmsh)
SimpleBox.FEMMeshGmsh.Elem42F2 (FEMMeshGmsh)
SimpleBox.FEMMeshGmsh.Elem39F4 (FEMMeshGmsh)
Then using the following python API:
sel=Gui.Selection.getSelectionEx()
I can check inside sel variable, my selections. (e.g.)
sel[0].SubElementNames[0]
The output is the name of the selected element as expected,
Elem0F1
My problem starts here :? . How can I identify this element named, Elem0F1, in the .inp file? Because my first element in the .inp file is 37 and not Elem0F1...
best regards,
Ekaitz.
EDIT: Typing the following in python API, I can print my elements
sel[0].Object.FemMesh.Volumes
(37L, 38L, 39L, 40L, 41L, 42L, 43L, 44L, 45L, 46L, 47L, 48L, 49L, 50L, 51L, 52L, 53L, 54L, 55L, 56L, 57L, 58L, 59L, 60L)
As expected, the first element of my .inp is 37L
However, I still do not know which element is identified with the selected ones.
bernd
Re: [Help] Selected element identification in .inp file
Postby bernd » Mon Sep 24, 2018 12:26 pm
would you post a simple example file ...
BTW: what do you need them for?
Jee-Bee
Postby Jee-Bee » Mon Sep 24, 2018 12:57 pm
EkaitzEsteban
Postby EkaitzEsteban » Mon Sep 24, 2018 1:26 pm
I am exploring and editing manually the .inp file for performing different frequency analyses.
I can attach a simple example file.
SimpleBox.FCStd
(9.31 KiB) Downloaded 10 times
bernd
Postby bernd » Mon Sep 24, 2018 2:46 pm
- Elem0F1 means Face 1 of element 0
- Elem42F1 means Face 1 of element 42
- Elem42F2 means Face 2 of element 42
- Elem39F4 means Face 4 of element 39
this is generated from Status line code from the index of the selection.
bernd
Postby bernd » Mon Sep 24, 2018 2:48 pm
FYI:
FreeCAD supports multiple materials too. You may make you model in FreeCAD directly.
EkaitzEsteban
Postby EkaitzEsteban » Mon Sep 24, 2018 3:08 pm
Thank you Bernd for the info. However, this simplebox have only 24 elements and it starts counting from 37 until 60 as seen here:
EkaitzEsteban
Postby EkaitzEsteban » Mon Sep 24, 2018 3:11 pm
FYI:
Yes I know, but the final objetive of the project is to manage different custom .inp files from a macro without modifying the structure of the mesh.
bernd
Postby bernd » Mon Sep 24, 2018 4:25 pm
24 volume elements, but a volume FEM mesh has edges and faces too. They are just not used for a volume analysis.
EkaitzEsteban
Postby EkaitzEsteban » Mon Sep 24, 2018 7:58 pm
Thank you for your annotation.
best regards,
Ekaitz.
