Angular Dimension From 3 Vertices
bejant
Postby bejant » Mon Sep 24, 2018 3:08 pm
Is it possible to create an angular dimension like this (ignore the circled one):
If not, do you think I should create a ticket for it?
Related help topic:
https://forum.freecadweb.org/viewtopic. ... 89#p258156
wandererfan
Re: Angular Dimension From 3 Vertices
Postby wandererfan » Tue Sep 25, 2018 12:36 am
No - 2 straight edges only. I'll have to check if Dimensions can handle 3 references. Everything so far is only 1 or 2.
Yes, please. It will get lost in the pile otherwise.
bejant
Postby bejant » Tue Sep 25, 2018 4:06 pm
Thanks, submitted as issue #3613
wandererfan
Postby wandererfan » Wed Oct 03, 2018 1:37 pm
3 point Angles implemented by git commit b569120131. TechDraw_Dimension_Angle3Pt
bejant
Postby bejant » Fri Oct 05, 2018 1:10 am
Thanks wf!
Postby chrisb » Fri Oct 05, 2018 5:54 am
From time to time we saw here people asking for Drawing+DrawingDimensioning WB. That's definitely over now.
wandererfan
Postby wandererfan » Fri Oct 05, 2018 11:59 am
I've been hearing that DD is better for a long time, but I've never seen a detailed comparison. If there is anybody out there with experience in both TD & DD, a "better/worse, missing, etc) feature comparison would be a big help to me.
meme2704
Postby meme2704 » Thu Oct 11, 2018 4:12 pm
Hi
This is only my opinion.
I think placement of views is easier with Drawing
With DD, I can place the lines of axes and change their appearance, and a line arrow for the text
on the other hand, I do not know how to modify the appearance of the hidden lines in the 2 cases
With DD we can add the tolerances = / - on the dimensions
In the 2 systems we can not change the numerical value of the dimensions, nor the symbols like the signs of diameter, Rays nor degree of angle
there is also no option to delete the decimal zero
This is not an exhaustive list
in attachment: the same drawing presented with the 2 systems
moyeu1.FCStd
(184.69 KiB) Downloaded 16 times
